1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. drhellcat12
    Eclair Dec 27, 2018
    drhellcat12 , Dec 27, 2018 :
    yes I did wipe the cache in recovery after updating! ok let me try the antutu app! thanks for the help! cheers!
  2. Q1545504703112
    Honeycomb Dec 27, 2018
  3. ReeGeeBee
    Eclair Dec 27, 2018
    ReeGeeBee , Dec 27, 2018 :
    а что за дичь с уровнем яркости?? почему подсветка щас на50% работает как раньше на 25%???
  4. drhellcat12
    Eclair Dec 27, 2018
    use VPN and connect to Canada! then search for the update! you will get it!
  5. cyberman_5145
    cyberman_5145 , Dec 27, 2018 :
    one weird issue that I have with latest update if anyone may help, if my device is locked I don't get WhatsApp calls n messages untill I unlock my device. I read in one of the post that I can do some changes in system idle process or likewise but I don't know what to do and where to locate it. can anyone please help me with this issue and suggest what to do if I need my messages delivered to me irrespective of the fact if my device is in sleep mode or not? I have tried selecting do not optimise option under battery for WhatsApp however it's of no use for my issue.
  6. G_Prashant_Kumar_Roy_75_
    Froyo Dec 27, 2018
  7. G1545926449207
    Cupcake Dec 27, 2018
  8. MLuthfi_Alif
    Eclair Dec 27, 2018
  9. Wrawoot12
    Eclair Dec 27, 2018
    Wrawoot12 , Dec 27, 2018 :
    No Problem bro
  10. Le_zOU
    Le_zOU , Dec 27, 2018 :
    crap I wanted to avoid that, well I'll wait until I get home with FTTH to run a backup and have a fast restore them :p
    thank you
  11. usb789
    Eclair Dec 27, 2018
  12. harshit.b.
    Jelly Bean Dec 27, 2018
    harshit.b. , Dec 27, 2018 :
    sd835 doesn't support dual volte so no.
  13. Rudraa26
    Eclair Dec 27, 2018
    Rudraa26 , Dec 27, 2018 :
    I don't know if its a bug or not... even not sure wether you guys are facing it or not... but m not able to pull down the notification panel properly in some cases!! specially when a call is running on notification panel... But I do respect the hardwork of OnePlus! Thanks a lot!
  14. Wrawoot12
    Eclair Dec 27, 2018
  15. G_Rona-k_Patel_Ufgk
  16. mjm1987
    Eclair Dec 27, 2018
    mjm1987 , Dec 27, 2018 :
    I used a VPN and connected to a server in Canada and it popped right up
  17. G_adarshnholla_adi_MdGw
    Froyo Dec 27, 2018
  18. adnannn81
    Eclair Dec 27, 2018
    adnannn81 , Dec 27, 2018 :
    yes install oxygen update and follow the steps
    usb789 likes this.
  19. mattam24
    mattam24 , Dec 27, 2018 :
    Did you try Settings -> Battery -> Battery optimization -> Tripple dot menu -> Advanced optimization and switched off the Optimization of Standby Mode?
    Yatin_Asri likes this.
  20. usb789
    Eclair Dec 27, 2018
