1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. sanjay BC
    Cupcake Dec 28, 2018
    Poojitha Mucheli likes this.
  2. Igor_VZ
  3. Yag1z
    Gingerbread Dec 28, 2018
    Yag1z , Dec 28, 2018 :
    No need all of these. Just download zip file than install it via recovery mode
  4. Sunil_Kumar_Kulkarni
    Donut Dec 28, 2018
    Sunil_Kumar_Kulkarni , Dec 28, 2018 :
    Thanks for the info but don't mention as kid in nxt time for any persons reply in this forum as ur not a father of OnePlus forum
    showstopper197 likes this.
  5. nageshyannapusal
    H1543233178973 likes this.
  6. GuptaAakash
    GuptaAakash , Dec 28, 2018 :
    Hi,
    It seems that for some reason ingame headset microphone do not work for some reason, while playing PUBG i noticed that you need to remove your headphones and then insert the headphone again and then the microphone works any one else face the same issu??
  7. G1545817291475
  8. sunilk295
    sunilk295 , Dec 28, 2018 :
    superb work from 1plus. Only one + is the mobile company which value it's customers... thank you..have a great new year
  9. Poojitha Mucheli
  10. NikhilJagtap
    Ice Cream Sandwich Dec 28, 2018
    NikhilJagtap , Dec 28, 2018 :
    Thanks for the info but don't mention as kid in nxt time for any persons reply in this forum as ur not a father of OnePlus forum​
    I didn't declare myself as your father nor Forum's. (Apologies if it had harmed your Pride or ego) I mentioned kid as you were asking question which is answered publicly again and again. The staged rollout will concern with servers in India are getting update after or before. It isn't case with incremental rollouts. Even your server had the update, it might take days to reach you. I did update using VPN: Canada as I am from India too. But my friend from Canada received the update later on.
    Here's your answer for other countries getting priority:
    With USA and Canada, wasn't it the Christmas Eve at their place and morning of 26th in India when update was released? The update release notes also mentioned it as a Christmas Gift.
    I hope you get it, if didn't, wait for the update or VPN as always.
  11. Sunil_Kumar_Kulkarni
    Donut Dec 28, 2018
    this is my first query and I have not asked questions again and again.
    NikhilJagtap likes this.
  12. NikhilJagtap
    Awesome. Hope you get the update ASAP and answers for your questions too.
    PS: Use search button too, mods are strict
    Sunil_Kumar_Kulkarni likes this.
  13. AnimatedKiller
    Honeycomb Dec 28, 2018
    AnimatedKiller , Dec 28, 2018 :
    @Yag1z
    From Beta to Stable you need to Factory Reset.
    I tried overlapping the Beta with Stable and got my phone locked down as the ROM was declared corrupted due to updating over Beta, it's an error which makes your phone untrusted and does not push further updates.
    The only solution was to Factory Reset and install through ADB to officially install the update correctly.
  14. Purabjain_70
    Froyo Dec 28, 2018
    Purabjain_70 , Dec 28, 2018 :
    it's safe as I did it for my OnePlus .
    cannot guarantee but generally nothing happens.
    use thunder vpn,select Canada and check for updates
    I did it and m loving it.
  15. G1545817291475
  16. NikhilJagtap
    It is over the air already. You will receive it and will be informed via notifications. You can also download the file from website and flash it or can use VPN to get the update instantly. (VPN will give you the update but not every time.)
  17. AnimatedKiller
    Usual Cupcake Opinions.
    Wait until you stumble across an issue :)
  18. Q1512762284801
    Donut Dec 28, 2018
  19. sunilk295
    FYI - have an issue with message and same has been provided as feedback...
  20. Tejas Waghela
    Eclair Dec 28, 2018
    Tejas Waghela , Dec 28, 2018 :
    No one knows, you can work around. Or might come by 31st.
