1409
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. abhimanyu_uk
    Gingerbread Dec 28, 2018
    abhimanyu_uk , Dec 28, 2018 :
    Mr_Cyrox
    Yeah the Pill command​
    tried enabling the command but it shows error device not found even when my device is connected with usb debugging on.
    PS I've got adb drivers installed earlier.
  2. ErynOP
    ErynOP , Dec 28, 2018 :
    Hello guys,
    Anyone else experiencing "lags" when scrolling ?
    Rgds,
    Eryn
  3. Mr_Cyrox
    KitKat Dec 28, 2018
    Mr_Cyrox , Dec 28, 2018 :
    Open Beta 24
    But it's technically the same...
    Open beta 22/24 was compiled at 2018-12-24
    Stable (Pie) was compiled at 2018-12-23
    Almost identical
  4. Bharath_siddharth
    Donut Dec 28, 2018
    Bharath_siddharth , Dec 28, 2018 :
    I can't find split screen option
  5. Mr_Cyrox
    KitKat Dec 28, 2018
    Is your connection between PC and device stable?
    Did you allow your PC to use USB debugging?
  6. G_Neeraj_joshi_IkFQ
    Cupcake Dec 28, 2018
  7. Mr_Cyrox
    KitKat Dec 28, 2018
    Can you share a screenshot of what you see?
  8. Bharath_siddharth
    Donut Dec 28, 2018
  9. abhimanyu_uk
    yup its stable.
    how can i Allow my pc to use usb debugging?
  10. U1510660318399
    Donut Dec 28, 2018
  11. Mr_Cyrox
    KitKat Dec 28, 2018
    It's a staged rollout
  12. asdeepak16
    Donut Dec 28, 2018
    asdeepak16 , Dec 28, 2018 :
    Well said
  13. G_Neeraj_joshi_IkFQ
  14. Bharath_siddharth
    Donut Dec 28, 2018
  15. A1514135395403
    A1514135395403 , Dec 28, 2018 :
    you can only see split screen option with the compatible apps otherwise it does not appear.
  16. Mr_Cyrox
    KitKat Dec 28, 2018
    It obviously won't work on apps that don't support split screen like the Community APP :rolleyes:
    Btw please don't use the APP and use the browser version it's far superior
  17. U1510660318399
    Donut Dec 28, 2018
    U1510660318399 , Dec 28, 2018 :
    it's an software they can give us ok like a update
  18. Mr_Cyrox
    KitKat Dec 28, 2018
    When you do samething that requires USB debugging for the first time with your PC the device will ask if you allow that PC to use USB debugging
  19. Bharath_siddharth
    Donut Dec 28, 2018
    U1510660318399 likes this.
  20. Mr_Cyrox
    KitKat Dec 28, 2018
    You're half right
    It's software and hardware most notably the OIS which is absent from the OnePlus 5/5T
