1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. nurjaman
    Cupcake Dec 29, 2018
    nurjaman , Dec 29, 2018 :
    My oneplus 5t battery has started draining rapidly after I upgraded to oxygen os 9.0 yesterday
  2. FAuzAn ul hAsAn
  3. ErynOP
    Gingerbread Dec 29, 2018
    ErynOP , Dec 29, 2018 :
    Hello,
    We blocked update only for you.
    Rgds,
    Eryn
    Yag1z likes this.
  4. nurjaman
    Get a vpn app from app store and dn set ur vpn to Canada and dn go to settings and search for system upgrade. You will receive your update.
  5. J1546105411975
  6. P1513674419821
    Eclair Dec 29, 2018
    P1513674419821 , Dec 29, 2018 :
    its a good update.. although I experience a few lags here and there, but I am sure the bug fixes will be out sooner or later!
    Yag1z and Qwert Luiop like this.
  7. J1546105411975
  8. Qwert Luiop
    Froyo Dec 29, 2018
  9. desperados83
  10. B1545889687412
  11. Divyanshu_Agrawal
    Froyo Dec 29, 2018
    Divyanshu_Agrawal , Dec 29, 2018 :
    post update caller image is getting cropped during incall notification, any solution other than removing the image
  12. R1545895764637
    B1545889687412 likes this.
  13. harshit.b
    Ice Cream Sandwich Dec 29, 2018
    harshit.b , Dec 29, 2018 :
    apparently it's a bug which will be solved in the next update.
    Divyanshu_Agrawal likes this.
  14. Divyanshu_Agrawal
    Froyo Dec 29, 2018
    download supervpn from playstore and set global vpn you will get the update
  15. angourakis
    Froyo Dec 29, 2018
    angourakis , Dec 29, 2018 :
    It will only show when a device is connect and communicating through it. It's the default behavior on Android Pie
  16. Tillya
  17. M1545814489278
    Donut Dec 29, 2018
    M1545814489278 , Dec 29, 2018 :
    is this is the app u telled
  18. ErynOP
    Hello,
    It's because we blocked update on your phone until you read the first post.
  19. G_All_in_One_channel_mCJ
    MihirKudale likes this.
  20. Divyanshu_Agrawal
    Froyo Dec 29, 2018
