1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. parag008
    Ice Cream Sandwich Dec 30, 2018
    parag008 , Dec 30, 2018 :
    And here is the pie we have been all waiting for a very long time.
    many users are facing some issues.
    i hope they will be solved soon.
    for me no issues yet.
    the changed ui is so much welcome.
    many more new and intuitive changes. defienitely worth the time of waiting.
    thank you oneplus for this update.
    many features like new gestures, dnd mode changes, ui changes and many more is so much appreciated.
    kudos to the developer team.
    edit on comment no. 2083:
    after using it for 3 days now.
    1. screen calibration doesnt seem to work properly qith night mode.
    2. third party apps notifications opening takes a bit of time.
    3. opening any app that has been cleared from recent app takes a second or so to open. so there is definitely a lag.
    4. battery seems to work fine.
    5. adaptive brightness is still in learning mode so it will get over soon.
    6. camera shutter sound stays on even it is off in camera settings.
    all the above bugs has been submitted. before anyone says to submit the bug.
    hope issuses will be resolved soon.
  2. Purabjain_70
    Froyo Dec 30, 2018
    Purabjain_70 , Dec 30, 2018 :
    After the update
    I just recorded video in 4k quality and played it back.
    it doesn't play for starting 4 to 5 seconds and then starts playing in 1X speed (fast forward)..
    Did anyone else face this problem
  3. G_mircea_ibAs
    Eclair Dec 30, 2018
    G_mircea_ibAs , Dec 30, 2018 :
    [QUOTE = "Razvan B., post: 19737690, membru: 1328541"] Nici o problema? [/ QUOTE]
    La mine nici o problemă chiar functoneaza minunat,daca faci update oprește în camera sunetul și nu vei avea probleme,eu așa am făcut,am șters cache din stocare și apoi din recuperare,update și totul ok
  4. 9478441880
    Froyo Dec 30, 2018
    drjat likes this.
  5. widamandhaga
    Cupcake Dec 30, 2018
    widamandhaga , Dec 30, 2018 :
    anyone have same issue with me?..
    everytime i select lock screen message, it's always says keeps stopping
  6. Z1515355786189
    Z1515355786189 , Dec 30, 2018 :
    so I'm not that tech savvy when it comes to intricate software / hardware details but will this update patch in Project Treble into our system as well?
    also, are there any major bugs related to battery it performance any of us should know about?
  7. Deyan Pavlov
    MihirKudale and Krzysztof_Mazur like this.
  8. B1520516414795
    Deyan Pavlov and MihirKudale like this.
  9. maxhospital
  10. Blacksmith2080
    Froyo Dec 30, 2018
  11. PokiX
    Jelly Bean Dec 30, 2018
    PokiX , Dec 30, 2018 :
    No. Maybe you have other settings different that me. You have other force close than in this settings?
    But this could also mean that your update is bad. Try clearing cache I'm recovery and if that doesn't work, you might need to factory reset.
  12. PokiX
    We have treble but not AB partitioning, but I don't see how it will have an effect for us, mostly for OP as updates have to be handle differently.
    Regarding battery and performance, all good for me. But make your own opinion: try. If not happy, backup and revert.
    Z1515355786189 likes this.
  13. Nagendra_Sai
    Froyo Dec 30, 2018
    Rajesh Sinha and MihirKudale like this.
  14. O1514188009589
  15. O1514188009589
  16. proharsh1
    Gingerbread Dec 30, 2018
    proharsh1 , Dec 30, 2018 :
    After update there is slightt issue in brightness? like i have to keep brightness more than 50% to view. previously i was able to see with 30% battery. any 1 can help?
  17. Nagendra_Sai
    Froyo Dec 30, 2018
    Nagendra_Sai , Dec 30, 2018 :
    R U from India if so did u get pie update directly or by using vpn
    E1517038814875 and MihirKudale like this.
  18. proharsh1
    Vpn Canada
  19. Nagendra_Sai
    Froyo Dec 30, 2018
  20. G_himanshu_sharma_MCak
    Donut Dec 30, 2018
