1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. 1abhi95
    Eclair Dec 31, 2018
    1abhi95 , Dec 31, 2018 :
    see downloading via VPN is safe
    u are on the same page
    just u are downloading it a bit before
    country specific nahi rehta update
    like when previous update came
    I updated it using VPN but later on due to bugs they cancelled the update and rolled out another update.
    the update I did had cover 80% of the new update so instead of 1.5gb I just got 135mb update and my change log was the same version was also the same
    and I never faced issue
  2. 1abhi95
    Eclair Dec 31, 2018
    are u facing any bug issues...??
  3. ronnie1601
    Cupcake Dec 31, 2018
    ronnie1601 , Dec 31, 2018 :
    Amazing! Done [e]1f44d[/e] Thanks!
  4. G1519005640596
  5. Hari_Dwivedi
    Gingerbread Dec 31, 2018
    Hari_Dwivedi , Dec 31, 2018 :
    I didn't try with heavy use but in normal moderate usage there is no bug till the time.. it is working smooth for me.. but there are several options which are not available but we're available on Android 8...you may locate those in detail on the update page 1 itself...
  6. O1518818717608
    Honeycomb Dec 31, 2018
    O1518818717608 , Dec 31, 2018 :
    Itni dikkat hai to VPN se kar le bhai Darr mat your phone won't explode[e]1f602[/e][e]1f602[/e]
  7. Keeru@oneplus5t
    Keeru@oneplus5t , Dec 31, 2018 :
    1abhi95
    and I never faced issue​
    I clearly said that "i don't appreciate download throughout VPN" & it's My view but i know changing VPN also safe but when we download throughout your country update that will bring some features related to local area if any.
  8. Manas_Mishra_1989
    Ice Cream Sandwich Dec 31, 2018
    Manas_Mishra_1989 , Dec 31, 2018 :
    There is nothing country specific in the official stable updates. If you see the update file name when it comes to your phone it will have something like GLO which is short for GLOBAL hence these updates are global and not country specific.
  9. SyedYusuf
  10. vamsi amar
    vamsi amar , Dec 31, 2018 :
    after installing Android 9 in my 5t mobile and I just connected Bluetooth it is not synchronising the voice properly and we are getting a breakup voice so could you please help on this.
  11. munikumar2003
    Eclair Dec 31, 2018
  12. Saravanancm014
    Donut Dec 31, 2018
    Saravanancm014 , Dec 31, 2018 :
    When will be this Android pie update come to OnePlus 3/3T??? We are waiting to celebrate new year with pie. Is there any beta version available for 3/3T???
    khushu_u likes this.
  13. munikumar2003
    Eclair Dec 31, 2018
    munikumar2003 , Dec 31, 2018 :
    use VPN app and select Canada then connect...go to settings and try update...I am using...pie is excellent... working good...
  14. qasimstar
    Donut Dec 31, 2018
    qasimstar , Dec 31, 2018 :
    no major camera improvements in pie update. company is not focusing on 5 or 5t. users want huge camera improvements like one the OnePlus 6 is getting in os 9.0.3 ota update.
  15. khushu_u
  16. akshayd335
    akshayd335 , Dec 31, 2018 :
    after updating Android pie in OnePlus 5T my battery is draining quickly [e]1f61e[/e]
  17. kishor_d91
    Eclair Dec 31, 2018
    kishor_d91 , Dec 31, 2018 :
    Used "Pie 9.0.0" as my daily driver and witnessed few issues which forced me to roll back to "Oreo 8.1".
    Cons:
    1) I was unable to download / update apps from playstore as I had to reboot my phone to get them installed.
    2) Fingerprint sensor didn't work when the phone is in idle state, had to press the powerbutton to wake the screen and then have to try to unlock my phone.
    3) Camer shutter sound is turned off by default yet getting click sound while taking fotos
    4) Unable to report these bugs in the feedback link as well, receiving errors when logging in.
    excluding these it's a great update.
  18. ABhi_Jethva
    ABhi_Jethva , Dec 31, 2018 :
    i cannot see new navigation gestures in my 5t after upgrading to pie .. any solutions ?
  19. gunjansharma1508
  20. G_mahendar_Singh_zTCY
