1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. yogeshchandra65
    Eclair Dec 26, 2018
    yogeshchandra65 , Dec 26, 2018 :
    My apps are not updating from play store after upgrading to Pie. It shows only downloading.... I have cleared cache and storage of play store app but nothing worked for me. Infact I have cleared my phone cache also.
    Can anyone help?
  2. drhellcat12
    Eclair Dec 26, 2018
  3. saini.aman001
    Eclair Dec 26, 2018
    saini.aman001 , Dec 26, 2018 :
    How did you know.... Have u recieved any officiall update from google.
  4. milind550
    Eclair Dec 26, 2018
    milind550 , Dec 26, 2018 :
    it's not a problem, it is new navigation feature added. if you can see all the options and read again then you will understand it.
    gagan_k_26 likes this.
  5. VenkUU
    Ice Cream Sandwich Dec 26, 2018
    VenkUU , Dec 26, 2018 :
    Do A Reset That Might Work out
  6. Mark J
    Eclair Dec 26, 2018
  7. Nikkhil
    KitKat Dec 26, 2018
  8. VenkUU
    Check Once Again It's Available On My 5T
  9. sethisidd
    Jelly Bean Dec 26, 2018
    sethisidd , Dec 26, 2018 :
    Thanks to the Team for their hard work...!!
  10. milind550
    Eclair Dec 26, 2018
    do not spread wrong suggestions.
  11. darpankapre
    Donut Dec 26, 2018
    darpankapre , Dec 26, 2018 :
    deviantartjr
    try this
    Go to Settings / Application manager. Scroll all the way right, to the "All" tab. Scroll down to "Google Play Store" and tap that row. Tap "Clear cache", then "Force Stop."
    Now go back to the home screen, and restart the app. See if that fixes it. If not, try the same thing again, but this time "Clear data" instead of cache.
    If that still doesn't work, go back to the Application manager, tap the menu button, and "Reset app preferences."​
    i did but then too it won't worked same issue again
  12. Pramodgowri
    Donut Dec 26, 2018
    Pramodgowri , Dec 26, 2018 :
    yeah I checked now it's not available on one plus 5 can you please put a screenshot of that mode
  13. TheRealGamer
    Lollipop Dec 26, 2018
    TheRealGamer , Dec 26, 2018 :
    EXCELSIOR !
  14. Bullo Oka
    Honeycomb Dec 26, 2018
    Bullo Oka , Dec 26, 2018 :
    point 3. was already implemented in 9.0.0
  15. VenkUU
  16. F_Sabari_JS_ncLW
    Cupcake Dec 26, 2018
  17. rinku2bapi
    Gingerbread Dec 26, 2018
  18. Pramodgowri
    Donut Dec 26, 2018
    VenkUU likes this.
  19. Rijo_David
  20. Rijo_David
