1411
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. munikumar2003
    Eclair Jan 1, 2019
  2. G_vinay_baseganni_AzBL
    Froyo Jan 1, 2019
  3. munikumar2003
    Eclair Jan 1, 2019
    munikumar2003 , Jan 1, 2019 :
    problem is battery saver...stop the battery saver and download apps and install then start battery saver... problem is solved
  4. G_vinay_baseganni_AzBL
    Froyo Jan 1, 2019
    G_vinay_baseganni_AzBL , Jan 1, 2019 :
    Apps downloading after I restarted. Problem Solved. Thanks
  5. Yogich1
    Cupcake Jan 1, 2019
  6. Sai teja1997
    Froyo Jan 1, 2019
    Sai teja1997 , Jan 1, 2019 :
    Yogich1
    i got new update but it's not 9.0.0 its 9.0.1 why???
    9.0.1 contains bug fixes that were present in 9.0 so you directly get 9.0.1
    Yogich1 likes this.
  7. Prince aamir
    Froyo Jan 1, 2019
    Prince aamir , Jan 1, 2019 :
    Hello guys,
    I have also received 9.0.1 directly via OTA last night and i had installed without any second thought because we are getting it via OTA and its official update. I have seen many people getting worry about directly getting 9.0.1 instead of 9.0.0.
    So guys it is the pie update and with bug fixes.
    So i wanna share what happened next after update installed and first boot to clear all people's confusion.
    1. Phone will take some time on one plus logo and then it will be started during first boot after update so don't make hurry or worry about that why my phon is not starting or it is stuck on that screen. Many people posted about that so i think its because they did something (used power button) during this time and stuck there only.
    2.After starting and unlocking my phone first time in pie, many background apps(mainly google play services) will try to adjust and install some updates.So in mean time don't do anything and leave system to make changes with thi new version of android.
    3. After few seconds,you will also receive One plus launcher update.Please note that i didn't cleared cache memory or anything to get this launcher update.If everything goes ok,you don't need to do anything fron your own.
    So this is normal process of after getting pie installed on your phone and you will get all changes automatically.
    My initial impression till now-
    I just observing little delay in switching recent app tab and during exiting many apps. Its very minor. I hope all will not find irritating during use in daily life and one Plus will improve in future.
    All others features are awesome.I am loving it.
    Tony0501 and Hithesh3101999 like this.
  8. Hithesh3101999
    Donut Jan 1, 2019
  9. Yogich1
    Cupcake Jan 1, 2019
    Yogich1 , Jan 1, 2019 :
    Thank you for the information
  10. Sai teja1997
    Froyo Jan 1, 2019
  11. J.Karthigeyan
    Cupcake Jan 1, 2019
    J.Karthigeyan , Jan 1, 2019 :
    I directly Got the Update For 9.0.1.Without 9.0.0 update.Any one Like Me From India.Will It cause Any Defects to System??
  12. Tcat007
    Honeycomb Jan 1, 2019
    Tcat007 , Jan 1, 2019 :
    All good here. 5t, magisk 18. No shutter sound when off, good pix. Everything works great. SOT report tomorrow.
  13. kartikwakodkar
    Donut Jan 1, 2019
  14. P1523078522560
    Cupcake Jan 1, 2019
    P1523078522560 , Jan 1, 2019 :
    i am unable to download any apps from the Google play store after update of android 9.0.1.please help me
  15. G_Cristiano_Hrithik_aFMD
    Froyo Jan 1, 2019
  16. G_Cristiano_Hrithik_aFMD
    Froyo Jan 1, 2019
  17. LEECOOPHER_5T
    Eclair Jan 1, 2019
  18. Yatin_Asri
    Gingerbread Jan 1, 2019
    Yatin_Asri , Jan 1, 2019 :
    Happy new year to all members in the forum. OOS 9.0.1 is out and I have already installed it just now. here is the changelog for the update package.
    GSVTech likes this.
  19. Rohan.M
    Yatin_Asri likes this.
  20. Yatin_Asri
    despite the update I can confirm one thing, WiFi issue is certainly resolved but play Store is still funny n slow. I cleared cache for play service & play Store from apps under settings and it's working fine now. pls do this after installation and then try using play Store you should be all good. will keep testing other features and it's stability and report back.
