1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. J1513561976107
    Donut Dec 26, 2018
  2. kumaryashwin
    Jelly Bean Dec 26, 2018
  3. Tejas Waghela
    Eclair Dec 26, 2018
    Tejas Waghela , Dec 26, 2018 :
    I believe after doing that it took a little time to update Play Store libraries. (I was able to see some notification on panel), probably it will works once it gets updated.
    You connected through WiFi, Right?
  4. kumaryashwin
    kumaryashwin , Dec 26, 2018 :
    Yep, oneplus always got one.
  5. Yoav Offek
    Gingerbread Dec 26, 2018
    Yoav Offek , Dec 26, 2018 :
    could be in an hour could be in two or even three weeks.
    as you probably already know oneplus doesn't release ETAs ever...
  6. Aziz_Amin_Oneplus
  7. Tejas Waghela
    Eclair Dec 26, 2018
    #1485 :)
  8. kumaryashwin
  9. G_Abhijeet_Chakroborty_I
    Cupcake Dec 26, 2018
    G_Abhijeet_Chakroborty_I , Dec 26, 2018 :
    i was connected through mobile network
  10. Bhushan sakpal
  11. Aziz_Amin_Oneplus
  12. C1519472166967
  13. kumaryashwin
  14. E1510854199402
    Froyo Dec 26, 2018
    E1510854199402 , Dec 26, 2018 :
    I’m not sure the adaptive brightness is not working but it certainly has changed from previous.
    The slider used to be very critical near the lowest setting, now it seems more linear across the whole slider, but it does seem to go a lot dimmer than before though. Almost too dim.
  15. niranvv
    Froyo Dec 26, 2018
    niranvv , Dec 26, 2018 :
    Got a workaround:
    Dial *#800#
    Go to OnePlus LogKit -> Function Switch -> enable VoLTE/VoWifi/VT switch. After a restart you will have the toggles even with SIMs without VoLTE Support.
    Should solve your problem :)
    Credits: Kruemelfelix
    hemalshah_85 likes this.
  16. G_Abhijeet_Chakroborty_I
  17. niranjc
    niranjc , Dec 26, 2018 :
    Happy Holidays!! Congrats to entire team
  18. Tejas Waghela
    Eclair Dec 26, 2018
    please try with WiFi, or just make sure you correct the settings in play store.
    should work.
  19. kumaryashwin
  20. niranvv
    Froyo Dec 26, 2018
    Got a workaround:
    Dial *#800#
