1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. San13anand
    Froyo Dec 26, 2018
    San13anand , Dec 26, 2018 :
    go to selfie, there slide to right you will find it.
  2. Shriresh
    Eclair Dec 26, 2018
    Shriresh , Dec 26, 2018 :
    Go to your app settings-> Oneplus launcher-> clear data. You will be welcomed with a Pie based navigation gestures + Recent app layout
  3. Shivam_093
    Donut Dec 26, 2018
    Shivam_093 , Dec 26, 2018 :
    as i said i have tried everything , but nothing works.
  4. Arun1106
    Cupcake Dec 26, 2018
    Arun1106 , Dec 26, 2018 :
    bro I m.having the same problem as well..try going to battery saver mode and see..it works as a temporary method for me
  5. FaleshC
    KitKat Dec 26, 2018
    FaleshC , Dec 26, 2018 :
    If you have better answer to "Why is there is no Clear Cache option in Android?", do share. i will include it in Q&A.
    Till then i think normal users could be fine with the article.
  6. rohitvermamech
    Eclair Dec 26, 2018
  7. San13anand
    Froyo Dec 26, 2018
    Just one thing which is little bit bugging me is that top black area between time and battery. I guess they did it for notch display like one plus 6/6t.
    would have been better if notification icon could come there.
    Then also i am happy with this update, UI is better than Oreo.
  8. upasana_m
    Gingerbread Dec 26, 2018
    upasana_m , Dec 26, 2018 :
    Been there, done that, helped others too.
    Thanks for the effort though. Cheers. [e]1f60a[/e]
  9. Harshjd
  10. Shivam_093
    Donut Dec 26, 2018
    we all finding the temperory solutions , but that's a genuine problem.
    Repost to OnePlus to fix it asap.
    Arun1106 likes this.
  11. jackytalib
  12. Moshaggy79
    Eclair Dec 26, 2018
  13. biharydani
    Froyo Dec 26, 2018
    biharydani , Dec 26, 2018 :
    thanks for the update!
    however, the Bluetooth keeps disconnecting from my Sony XM3 headphones from my 5T. anyone know a fix?
    works fine with a OnePlus 6T.
  14. Awais.r11
    Eclair Dec 26, 2018
  15. P1514290860722
    P1514290860722 , Dec 26, 2018 :
    hello oneplus,
    there is a bug in camera app, shutter sound is active even when you uncheck the option,kindly go through it
  16. G_Boris_Sweden_lHuW
  17. APhaniSankara
  18. Wildvine
    Wildvine , Dec 26, 2018 :
    There is a word called Patience in the dictionary. Sometimes you have to have it.
    BTW I am a OP3 owner ;)
  19. rahuljaiswal739
    Donut Dec 26, 2018
  20. bremmerie
    Froyo Dec 26, 2018
    bremmerie , Dec 26, 2018 :
    Did the manual update and installed it. Works fine. Thx oneplus for the christmas pie update.
