1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. juliomg
    Cupcake Dec 26, 2018
    juliomg , Dec 26, 2018 :
    Hello, is it possible to change the position of the clock in the status bar from the left to the center of the screen? In previous OS it was possible to do!
    Thanks
  2. Carfs
    Froyo Dec 26, 2018
    Carfs , Dec 26, 2018 :
    Running like a charm so far! Great work 1+ Team!
  3. Murdana
    Gingerbread Dec 26, 2018
  4. Greedygutz
  5. badaboom_rD
    Donut Dec 26, 2018
  6. VenkUU
    Ice Cream Sandwich Dec 26, 2018
    VenkUU , Dec 26, 2018 :
    no
  7. nemo_8491
    Donut Dec 26, 2018
  8. nemo_8491
    Donut Dec 26, 2018
    nemo_8491 , Dec 26, 2018 :
    same here .. used wifi as well but it's not working
  9. S1524977213951
    Donut Dec 26, 2018
  10. G_Mariappan_R_LpDH
    Donut Dec 26, 2018
  11. siva_sk
    siva_sk , Dec 26, 2018 :
    check it out front portrait is there
  12. vtambade
    vtambade , Dec 26, 2018 :
    For me on OP5, it is not.
  13. suraj_offl
    suraj_offl , Dec 26, 2018 :
    a small doubt, pill gesture is only for OnePlus 5T ? is that the new gesture mentioned in change log ?
  14. DogeAlpha
    Honeycomb Dec 26, 2018
    DogeAlpha , Dec 26, 2018 :
    For those whose play store doesn't work they can try uninstalling play store updates and then installing latest play store from apk mirror
  15. magnusenorson
    Eclair Dec 26, 2018
    magnusenorson , Dec 26, 2018 :
    my op5 feels crazy fast after the upgrade! was going to buy a second hand op6 tomorrow but having second thoughts now. thanks!!
  16. vishnuvardhanv
  17. rahuljaiswal739
    Donut Dec 26, 2018
  18. amirul_lisan
    amirul_lisan , Dec 26, 2018 :
    in bright day light, took this photo after the update. Zoom into the Face and see the improvement.
  19. HBP87
    HBP87 , Dec 26, 2018 :
    To enable/disable pie gestures on OnePlus 5:
    1. Go to settings>Buttons & gestures>Buttons>enable On-Screen nav bar.
    2. Turn on USB Debugging from developer options and connect your phone to your pc.
    3. Open command prompt.
    4. Run this command :
    adb shell settings put secure swipe_up_to_switch_apps_enabled 1
    To disable:
    Do the same thing, just replace the command:
    adb shell settings put secure swipe_up_to_switch_apps_enabled 0
    Mr_Cyrox and angourakis like this.
  20. ajmms1999
    amirul_lisan likes this.
