350
OxygenOS 9.0.10(9.0.11 Hotfix) OTA for OnePlus 6T
  1. ironass
    Lollipop Jan 22, 2019
    ironass , Jan 22, 2019 :
    Plug the phone in whilst downloading or use your PC to download and copy to the phone is what most users do.
  2. St_Jacob
    Gingerbread Jan 22, 2019
    St_Jacob , Jan 22, 2019 :
    I think he means about update itself. Yup battery drains like hell [e]1f609[/e]
    ironass likes this.
  3. ironass
    OK, thanks. that was an ambiguous post.
    Strange that a few users complain about poor battery life on OxygenOS 9.0.11 and yet the majority of users, worldwide, are reporting phenomenal battery life from this build.
    G_Mr_.... likes this.
  4. St_Jacob
    Well mine story is known. 905 was the best, everything later on only worse. But Ive been forced to do a factory reset recently and... I can see battery backup improve.
    adi1001, ironass and T1547670916681 like this.
  5. Rajan chemicals
    Cupcake Jan 22, 2019
    B1539751386785 likes this.
  6. St_Jacob
    ROTFL
    Auristic and ironass like this.
  7. ironass
    Doing a Factory data Reset is a good idea. I always do one after an update to ensure that there is no detritus left over from the previous firmware and that all my apps and settings are fresh. Without doing that, it is hard to comment on a new build as it may well be corrupted phone settings, apps or settings from your previous firmware that is causing an issue. It also gives you a chance to check that all your Play Store apps have been updated for Android 9.0, Pie, as a heck of a lot have not and can cause issues. Good luck with your phone after the FDR!
    Desejmon and St_Jacob like this.
  8. Rajan chemicals
    Rajan chemicals , Jan 22, 2019 :
    while charging screen becomes black but in apple while charging phone we shoud know about changing percentage
  9. ChefChaudart
    Honeycomb Jan 22, 2019
    ChefChaudart , Jan 22, 2019 :
    Forget to add in your sentence "In my case"
    ironass likes this.
  10. shuvajyoti
    Froyo Jan 22, 2019
  11. ironass
    No, it should not if you are updating from, say, 9.0.10 stock OxygenOS firmware. I always recommend backing up everything before updating... just in case. ;)
  12. Amarjeet Sahoo
    Amarjeet Sahoo , Jan 22, 2019 :
    Hi iron ***..what stats are you getting?
  13. ironass
    Amarjeet Sahoo likes this.
  14. Desejmon
    Ice Cream Sandwich Jan 22, 2019
    Desejmon , Jan 22, 2019 :
    Normal stats I would say when it hits 50% you get around 4hrs SOT more than this is cheating like no heavy usage by CPU or GPU only screen is working. I'm too obsessed about the battery. I'm cheating myself boosting SOT by night viewing ig/internet :rolleyes: SICK. Anyway battery is very good on this phone comparing this to my OP3T that had 2 years and used to get 5hrs SOT everyday. So. Thanks OnePlus for a good work!
    St_Jacob likes this.
  15. JayasundarRB
    Ice Cream Sandwich Jan 23, 2019
    JayasundarRB , Jan 23, 2019 :
    Allow the phone to settle with the battery after the new update. Initially after 9.0.11, battery drained a lot. But now my battery seems to ok with 6 to 7 hours SOT with 3 to 4 hours of COC gaming.
    May be allow the battery to settle down with 4 to 5 cycles. It will work fine.
    G_Mr_...., T1547670916681 and ironass like this.
  16. 20209641
    Eclair Jan 23, 2019
  17. fidus62
    Jelly Bean Jan 23, 2019
    fidus62 , Jan 23, 2019 :
    then, when the patch is created!
  18. Kartik.Shanwad
    Froyo Jan 23, 2019
    G_Mr_.... and argenter like this.
  19. karthikeyans1977
    Gingerbread Jan 23, 2019
    karthikeyans1977 , Jan 23, 2019 :
    thank you for the clarity. really appreciate it
    f00tbaLL likes this.
  20. adityarajsaha
    Froyo Jan 24, 2019
    adityarajsaha , Jan 24, 2019 :
    After this update wifi and cellular network reception is getting worst.
    sometimes wifi is not working and cellular network also not working.
    on playstore trying to download some app but its shows downloading........
    while using messenger phone getting freezed.
    lots of bugs on this update.
    Please give a stable update as soon as possible with latest security patch and improve the stability and overall software experience as the oxygen os known for his accuracy,faster update,stability,speed and improvements.
