350
OxygenOS 9.0.10(9.0.11 Hotfix) OTA for OnePlus 6T
  1. A1543585649480
    Cupcake May 30, 2019
  2. ironass
    Lollipop May 30, 2019
    ironass , May 30, 2019 :
    Why are you on a 6 month old update is a better question? :confused:
  3. A1543585649480
    A1543585649480 , May 30, 2019 :
    I am talking about new beta 11
  4. ironass
  5. A1543585649480
  6. A1543585649480
  7. ironass
    If you manually downloaded the Open Beta update and installed via Local Upgrade, it will probably not show the changelog.
  8. A1543585649480
    ya I updated by local upgrade
  9. ironass
    That's the reason you are not showing a changelog then.
  10. A1543585649480
  11. ironass
    If you posted in the correct forum that I linked you to, you would immediately see the answer to your question in post #809. That's why we have separate threads.
    Xnatty likes this.
  12. A1543585649480
  13. Xnatty
    Honeycomb May 30, 2019
    Xnatty , May 30, 2019 :
    why aren't "OLD" beta/stable threads even being closed after another a newer one comes out?
    Staticx likes this.
  14. A1543585649480
    I don't know what should I do...
  15. ironass
    Because people like myself, need to sometimes refer back to them or may even have decided to, "stick", on that firmware.
  16. Xnatty
    report it as a bug! or ask in the link @ironass gave you.
    Staticx likes this.
  17. Xnatty
    oh I see. didn't think about it..
    Staticx likes this.
  18. ironass
