350
OxygenOS 9.0.10(9.0.11 Hotfix) OTA for OnePlus 6T
  1. avinashmaddala
    Cupcake Dec 22, 2018
  2. udaykn05
    Gingerbread Dec 22, 2018
    udaykn05 , Dec 22, 2018 :
    On Normal usage or heavy..I clock upto 1 day plus with Normal usage .
  3. muharrem1961
  4. I1545468583630
  5. Ash8397
  6. Abhishek Raj_2109
    Froyo Dec 22, 2018
    Abhishek Raj_2109 , Dec 22, 2018 :
    what is your on screen time ?
  7. Ash8397
  8. Abhishek Raj_2109
    Froyo Dec 22, 2018
  9. Ash8397
  10. Abhishek Raj_2109
    Froyo Dec 22, 2018
  11. Ash8397
    Ash8397 , Dec 22, 2018 :
    45 mins max, since it lacks the headphone jack
  12. G1542828796976
    amlanbaidya likes this.
  13. Abhishek Raj_2109
    Froyo Dec 22, 2018
  14. JayasundarRB
    Ice Cream Sandwich Dec 22, 2018
    JayasundarRB , Dec 22, 2018 :
    Screen on time above 6 hours is normal bro.
  15. Ash8397
    1 game lasts half an hour, so that way it's usually 5%, I feel like I'm getting interrogated
  16. JayasundarRB
    Bro, have you got OTA pop up or through VPN?
  17. Abhishek Raj_2109
    Froyo Dec 22, 2018
    no bro...my battery drain is 10% in 30 mins... wondering why is it so much in my case ?
  18. JayasundarRB
    yes bro. Do install 9.0.10 and after update wipe cache and reboot the device. You can do either way by updating to 9.0.7 and then 9.0.10. Only update size varies if you directly update from 9.0.06 to 9.0.10.
  19. JayasundarRB
    No problem i guess bro. Even in PUBG or Utorrent app for 30 minutes continous usage is normal. Even it happens with me. Just enjoying :). Just ensure wiping cache after each update, it will ensure a good battery life :) Also i observe 8GB variant battery drain higher than a 6GB, since it pulls some more power for smoother performance
  20. nitishkhullar1187
    Honeycomb Dec 22, 2018
    nitishkhullar1187 , Dec 22, 2018 :
    omg...... u r so full of urself
