162
OxygenOS 9.0.10 OTA for the OnePlus 5 and OnePlus 5T
  1. HalCapone
    Honeycomb Mar 10, 2020
    HalCapone , Mar 10, 2020 :
    Yes I did.
    paulomodesto likes this.
  2. porkuspious
    Froyo Mar 10, 2020
    porkuspious , Mar 10, 2020 :
    Release 11 is looking considerably better than the 10 release so far. I had the call lag, also massive sms issues using textra with 10.
    And 11 feels considerably more responsive than 10.
    So the question is did they even test the last release - we were the testers - it was a disaster and completely unprofessional to release it.
  3. Waveform Modifier
    Marshmallow Mar 10, 2020
    Waveform Modifier , Mar 10, 2020 :
    Don't think anyone here will have an answer. Pretty sure there is someone testing it, but it will be such a sample size, it wouldn't be much of a test.
  4. porkuspious
    Froyo Mar 10, 2020
    I rolled back from 10 to 9 a while ago because it was unacceptable. Then tonight I updated directly from 9 to 11 from an Oxygen Updater download using twrp. Not sure it was a sample size. Thanks for your response.
    mysticrainman likes this.
  5. DominikTV
    Eclair Mar 11, 2020
    im.ashish likes this.
  6. Waveform Modifier
    Marshmallow Mar 11, 2020
  7. im.ashish
    Honeycomb Mar 11, 2020
    im.ashish , via OnePlus 5T , Mar 11, 2020 :
    Beta is still better then this stable crap update.
    once android 10 is live we'll directly update to android 10
  8. realshivam07
    Froyo Mar 11, 2020
  9. NIK3SH
    Froyo Mar 11, 2020
    NIK3SH , via OnePlus 5 , Mar 11, 2020 :
    9.0.11 is on its way with below Changelogs
    • Updated Android security patch to 2020.02
    • Improved system stability and fixed general bugs
  10. G_Santhosh_Naik_jOkY
    Gingerbread Mar 11, 2020
  11. dhimansachin2006
    Eclair Mar 11, 2020
  12. Abhi739
    Cupcake Mar 11, 2020
  13. Abhi739
    Abhi739 , Mar 11, 2020 :
    Yes definitely.
  14. Neeket07
  15. 27itachi
  16. bsk.madhavi@gmai
    Froyo Mar 11, 2020
    FusionBomber likes this.
  17. LamarrCZ
    LamarrCZ , via OnePlus 5T , Mar 11, 2020 :
    Thanks for the info with Oneplus camera v 3.8.109.. it works flawlessly even with Google Lens integrated.
    Update 9.0.11 works smoothly, phone call bug is finally fixed.
    I have root with Magisk, works totally fine so this update is safe to flash. Also, battery life got better for my taste, even with stock kernel.
  18. Keerthyvasan26
    Eclair Mar 11, 2020
    jpgu likes this.
