162
OxygenOS 9.0.10 OTA for the OnePlus 5 and OnePlus 5T
  1. kumaryashwin
    Jelly Bean Jan 15, 2020
    kumaryashwin , Jan 15, 2020 :
    Uninstall tell update from the oneplus dashboard app.
  2. kumaryashwin
    Use search option. For better results
    Petr.114 likes this.
  3. kumaryashwin
    This got nothing to do with the update
  4. Ankampally Bharath
    Cupcake Jan 15, 2020
  5. Ankampally Bharath
  6. kumaryashwin
    That's not ture. Has it been mentioned any where? That we need 9.0.10.
    Perhaps you were taking about vowifi. Not android 10
  7. Ankampally Bharath
    Ankampally Bharath , via OnePlus 5T , Jan 15, 2020 :
    anyways looking forward for Android 10
    Thank you
  8. kumaryashwin
  9. kumaryashwin
    Its good you are looking forward to android 10. But update are mend to improve your experience. Not derail it. This update has some flaws which will be solved with next hot fix.
    But still someone who don't care for their productivity and just want to run with the crowd. Go ahead, it's your choice to make.
  10. Waveform Modifier
    Marshmallow Jan 15, 2020
    Waveform Modifier , Jan 15, 2020 :
    You can help yourself by reading! Don't be lazy.
    Sid_Ck likes this.
  11. P1512569276852
    Gingerbread Jan 15, 2020
  12. Trevor.Hawkes
    Ice Cream Sandwich Jan 15, 2020
    Trevor.Hawkes , Jan 15, 2020 :
    Strangely, running my 5 on 9.0.10, I do not have the delay before disconnect nor a problem sending or recieving text messages. The noise cancellation switch is on as I read that is in some way causing the disconect problem.
    Maybe OnePlus tested the update on a device setup and loaded with the same apps as mine.
  13. zivk123123
    Eclair Jan 16, 2020
    thiagomz likes this.
  14. olzhas.tomas
    Donut Jan 16, 2020
    olzhas.tomas , via OnePlus 5T , Jan 16, 2020 :
    Dear members, let us not discuss Android 10 here. Who has updated recently, did you find any issues with call disconnect delays? I have just received an update notification this morning.
  15. olzhas.tomas
    Donut Jan 16, 2020
    When did you update, how many days or hours ago? thanks
  16. Waveform Modifier
    Marshmallow Jan 16, 2020
    Waveform Modifier , Jan 16, 2020 :
    It is just a delayed auto notification dismiss. Nothing more. Your calls will end when you end it.
  17. san94fbr
    Gingerbread Jan 16, 2020
  18. Waveform Modifier
  19. san94fbr
    san94fbr , via OnePlus 5T , Jan 16, 2020 :
    I can find noise cancellation option..but no WiFi calling by default.
