144
OxygenOS 9.0.10 OTA for the OnePlus 5 and OnePlus 5T
  1. E1572897130505
    Cupcake Jan 17, 2020
  2. Waveform Modifier
    Marshmallow Jan 17, 2020
    Waveform Modifier , Jan 17, 2020 :
    Restart your phone? Reinstall the app? Mine works, so, you can't blame it on the OS.
  3. Giovanni oneplus
    Cupcake Jan 18, 2020
  4. Waveform Modifier
    Marshmallow Jan 18, 2020
    Waveform Modifier , Jan 18, 2020 :
    You do know you need to redo your root if you update every time, right?
    Petr.114 and zer0se7en like this.
  5. Omar5T
    Gingerbread Jan 18, 2020
  6. Waveform Modifier
  7. Maniatmm1985
    Donut Jan 18, 2020
  8. Waveform Modifier
    The community knows. Please read the forum and keep up.
  9. devkaundal
  10. manishraju
  11. meetvora95
  12. J1579319596707
    J1579319596707 , via OnePlus 5 , Jan 18, 2020 :
    The update of this new software is not Good.Because when I cancelled/cut the phone ,the phon do not cancelled .Its shown up to the notification.then I swipe down the notification bar and cancelled the phone call. Sometimes It worked or sometimes not.Its lagging.
    Edited for moderator (mojoyoyo77).
  13. krazzy_5999
    krazzy_5999 , via OnePlus 5T , Jan 18, 2020 :
    Yup that's right ...facing same issue on op5t ...maybe they should update it quickly ...
  14. NShankaraN
    Donut Jan 18, 2020
    NShankaraN , via OnePlus 5 , Jan 18, 2020 :
    Hi All,
    I updated my OP5 to 9.0.10 and noticed the call disconnection issue that was reported in this thread.
    I cleared the Storage of the "Phone" app from settings and this has solved the delay in disappearance of call notification after cutting the call.
    Apart from this , I dont see any other issues in this update and all other social media apps are running smooth for me.The battery backup is normal as it was earlier.
  15. Q1527130454896
  16. I1516719084438
    Donut Jan 18, 2020
    I1516719084438 , Jan 18, 2020 :
    After update there is a delay in disconnecting the call. Please help how to fix this or any other patch is going to release.
    R1569681640305 likes this.
  17. G_Prashant_Chandrakar_DA
    G_Prashant_Chandrakar_DA , Jan 18, 2020 :
    the new update is worst at all waste of data and waste of time
    this caused my phone slow and even the sim and network is not responding properly
  18. gsviradiya
  19. mfmfaalil
  20. G_Prashant_Chandrakar_DA
    did you got any solution for this . even i have problem of this
    R1569681640305 and SanvedChavan like this.
