162
OxygenOS 9.0.10 OTA for the OnePlus 5 and OnePlus 5T
  1. Deactivated User
    Jan 21, 2020
  2. PANKAJ705787
    Cupcake Jan 21, 2020
    Sunil_Kumar_Kulkarni likes this.
  3. PANKAJ705787
    PANKAJ705787 , Jan 21, 2020 :
    also face this problem
  4. Rahul_S_S
    Rahul_S_S , via OnePlus 5T , Jan 21, 2020 :
    Can you tell me reason why delay after call disconnection is a good feature?
  5. Akashdeep081095
    Eclair Jan 21, 2020
  6. Trevor.Hawkes
    Ice Cream Sandwich Jan 21, 2020
    Trevor.Hawkes , Jan 21, 2020 :
    Mine also smooth and I am on OnePlus launcher.
    Deactivated User likes this.
  7. smith.pranjul
    Honeycomb Jan 21, 2020
  8. Trevor.Hawkes
    Is this delay on all calls or only incoming. I don't see a delay but have only tried it on outgoing calls so far.
  9. smith.pranjul
    smith.pranjul , via OnePlus 5 , Jan 21, 2020 :
    When you hang up a call, there's a delay. You will see the call going on for 3-4 seconds in the status bar.
  10. Sunil_Kumar_Kulkarni , via OnePlus 5T , Jan 21, 2020 :
    Same issue is happening in my mobile too after installing new update!!!
    Hope OnePlus team will look after this issue n provide the solution in next OTA
    smith.pranjul and anshulgharde like this.
  11. PSSF23
    Gingerbread Jan 21, 2020
    PSSF23 , via OnePlus 5T , Jan 21, 2020 :
    This morning the WiFi modem is not working, solved after restarting the phone. During the restart, the OnePlus logo became black and white (like in reading mode) but returned to normal after booting up.
  12. Trevor.Hawkes
    Does it do it on incoming or outgoing calls. Or both?
  13. markini
    Nougat Jan 21, 2020
  14. krazzy_5999
    krazzy_5999 , via OnePlus 5T , Jan 21, 2020 :
    hey there..again saw a problem with my op5t update ..when I try to use contacts from dashboard it always shows the last contact which I dialed..it makes a lot of problem when someone is in hurry to make a important call..I don't know if other also had the same issue if anyone has a solution then please let me know..
    jay5t likes this.
  15. Jontalk5
    Jontalk5 , Jan 21, 2020 :
    After the 9.0.8 update, the Default sound setting would ring instead of the SMS choice when I got a text message. After the 9.0.9 update, the Smart WiFi/auto-connect feature quit working. After doing a hard reset, it was fixed but now with the .10 update, its returned again. Phone runs fine, battery life is good, no other problems. While the sound & Smart WiFi are minor, the bugs were never resolved in the last 2 updates.
  16. stark2991_PL
    KitKat Jan 21, 2020
  17. lunchboxLarry
    lunchboxLarry , via OnePlus 5T , Jan 21, 2020 :
    I found mine to be a little quicker I suspect it got a little freed up with the refresh possibly
  18. lunchboxLarry
  19. jay5t
    jay5t , via OnePlus 5T , Jan 21, 2020 :
    make sure to let OnePlus know using the feedback feature
    krazzy_5999 likes this.
  20. Waveform Modifier
    Marshmallow Jan 22, 2020
    Waveform Modifier , Jan 22, 2020 :
    Because if you bother to look. OnePlus said Q2 2020. Last I checked, we are in Q1 2020.
