162
OxygenOS 9.0.10 OTA for the OnePlus 5 and OnePlus 5T
  1. N1579679454622
    Cupcake Jan 22, 2020
    N1579679454622 , Jan 22, 2020 :
    call end delay
  2. Ganesh Ramesh
    Ganesh Ramesh , Jan 22, 2020 :
    Hi The update on 9.0.10 has bugs,
    1. After ending call it still being continue for few seconds in notification bar
    2. Concall / Call merge has bugs
    3. Has issue with Bluetooth audio device
    Please Suggest how to resolve..?
    IJShannon likes this.
  3. Niks_op5
    Eclair Jan 22, 2020
    Niks_op5 , via OnePlus 5 , Jan 22, 2020 :
    This particular update have bugs related to notification of call and general apps like whatsapp sms and Instagram. i hope one plus team will fix this asap!!
  4. vmahesh88
    vmahesh88 , Jan 22, 2020 :
    what is the fix for delay after call disconnection issue? facing this since latest update
  5. Trevor.Hawkes
    Ice Cream Sandwich Jan 22, 2020
    Trevor.Hawkes , Jan 22, 2020 :
    I've tested both incoming and outgoing. Firstly hanging up while still ringing then hanging up after the call connected. The call indicator disappeared immediately every time.
    Tried hanging up both from the 1+5 and then the other phone. The only thing that I saw was a momentary delay after the other phone hung up. That's to be expected.
    Strange.
    Hopefully a silly question but did you clear the phone app cache.
  6. smith.pranjul
    Honeycomb Jan 22, 2020
    smith.pranjul , via OnePlus 5 , Jan 22, 2020 :
    May it's not significant on your device. On my OP5, the call remains active for anywhere near 4-5 seconds (visible on status bar). Both on incoming and outgoing calls.
    KetanParmar and dr@phani like this.
  7. vivekmodha , via OnePlus 5T Midnight Black , Jan 22, 2020 :
    Ganesh Ramesh
    agree with you! look fwd to solve ASAP @Manu J.
    KetanParmar likes this.
  8. Trevor.Hawkes
    What about the phone app cache ?
  9. smith.pranjul
  10. I1579679026993
    Donut Jan 22, 2020
    I1579679026993 , Jan 22, 2020 :
    here are the list of problems with this update:
    1. Call not getting disconnected - So if you disconnect the call, it will still be active but under notification tab unless you press Hung-up to finally close the call. Very irritating and serious privacy issue...
    2. Apps performance has significantly reduced: After the update, Apps does not open within reasonable time. U try to open the app but it will take sweet time of say 2 minutes. By the time your early attempted app will pop up and this keep going on...
    3. Interest Speed has reduced: internet speed has gone down after the update. 5T is taking longer time in loading pages.
    PS: have not seen a singly improvement or bug fix as claimed by developer...There has been no improvement on any major function of the phone...
    no improvement in Camera Performance
    No improvement in call performance (even this become serious privacy issue)
    No improvement in app performance (even performance has gone down)
    No improvement in internet performance (even performance has gone down)
    no improvement whatsoever in UI
  11. I1579679026993
    Donut Jan 22, 2020
    Beware, dont install that..it will actually degrade ur phone's performace
  12. I1579679026993
    Donut Jan 22, 2020
    Hey...update means improving user experience..not reducing it...they should not offer any update if they cannot do that with conviction...I was not having any significant issue with earlier version..
  13. Trevor.Hawkes
    Ok, sorry.
    I normally clear settings app cache as well as the app having the problem. I have no real idea as to why I do but I do.
  14. Trevor.Hawkes
    Sticking to that rule would mean no updates ever.
  15. hassan5482
    Gingerbread Jan 22, 2020
    hassan5482 , via OnePlus 5T , Jan 22, 2020 :
    I've taken the approach to see what others are facing, before deciding whether to update this time around.
    If there's a further update due soon, I'll be doing the same also. the download of the update is available, but I'm not being forced to update.
    I guess if the phone is restarted or the battery reached empty, this is when it might update, so I'm just charging my battery when it gets low. Still get over a days battery life and it's still fast enough a couple of years later.
    Although a fair few people are irritated by this update, in the grand scheme of things, it's first world problems.
  16. sachkharb
    sachkharb , Jan 22, 2020 :
    I wish you give this advice little bit earlier
  17. zer0se7en
    zer0se7en , via OnePlus 7T , Jan 22, 2020 :
    Are you complaining to me? Dude, I am not a OnePlus employee.
    Thing is Softwares are not that easy to make. Let alone tweak it for an update. Sometimes you fixed some and at the same time break some without noticing it. This is why this community was made. For us to experience the good and the bad of their products.
    Now if you have a problem with your 5T after updating, try to look for some workaround. Chances are you're going to find one. That's what I and some users always do. Complaining here or to me won't do a thing.
    Manjunatha J likes this.
  18. pabbathikalyan
  19. Deactivated User
    Jan 22, 2020
  20. ruchiamgaonkar
    ruchiamgaonkar , Jan 22, 2020 :
    same here
