125
OxygenOS 9.0.11 OTA for the OnePlus 5 and OnePlus 5T
  1. Arsath1994
    Froyo Mar 20, 2020
    Arsath1994 , Mar 20, 2020 :
    Agreed
  2. Rishi23s
    Cupcake Mar 20, 2020
    Rishi23s , via OnePlus 5T , Mar 20, 2020 :
    yes the Heating issues are there along with wifi connection getting lost.
  3. rarog
    Lollipop Assistant Head Moderator Mar 20, 2020
    rarog , Mar 20, 2020 :
    Thx for clarifying this for the people. This is how it works internationally for every provider. The only change is if the call data is routed via mobile network or wifi to the servers of the provider. Especially now that 4G and newer also just use IP protocol internally it doesn't matter to them, how the (voice) data reaches the servers. But the charges for call services do not change by the way data is routed internally, because one pays for having the number and connections to and form the number, so the plan works the same.
    Kusai_Ghadiyali and PratikGadani like this.
  4. Photographyeyecatching
    Gingerbread Mar 20, 2020
    Photographyeyecatching , via OnePlus 5 , Mar 20, 2020 :
    i am not facing that kind of problem. i am even hearing this 1st time
  5. Photographyeyecatching
  6. PratikGadani
    Eclair Mar 20, 2020
    PratikGadani , via OnePlus 5 , Mar 20, 2020 :
    Agreed. Its written that the service is free without any charges, not the calls.
    Its marketing strategy with misleading information.
  7. Photographyeyecatching
    than we should complaint about it.
  8. PratikGadani
    Eclair Mar 20, 2020
    As Rarog said above its the same internationally. I don't think complaining can help. They have not said anywhere that calls will be free. They are saying wifi calling service is free
  9. Rahat.sahriar
    Rahat.sahriar , Mar 20, 2020 :
    clear gallery cache
  10. Photographyeyecatching
  11. Q1573498478063
    Q1573498478063 , via OnePlus 5T , Mar 20, 2020 :
    Hi, I need some help. I installed the OxygenOS 9.0.11 on my op5t through twrp.. after installing it my twrp was gone and I again installed twrp through fastboot. then I flashed magisk using it but my phone is going to twrp after every boot... need some solutions to work it out and install magisk. TIA
  12. Rahat.sahriar
    tap long gallery icon..then go to app info and go to storage..then clear cache
  13. Photographyeyecatching
  14. e1zemun
    Donut Mar 20, 2020
    e1zemun , Mar 20, 2020 :
    after instal twrp uninstal magisk, flash OS, wipe cashe and davlik, flash magisk, reboot
    Qwert Luiop and Q1573498478063 like this.
  15. Q1573498478063
  16. Q1573498478063
    Q1573498478063 , Mar 20, 2020 :
    thanks it worked!
  17. G_Sanchit_Bhatnagar_dSYB
  18. Waveform Modifier
    Marshmallow Mar 20, 2020
    Waveform Modifier , Mar 20, 2020 :
    No one will have that. It will be ready when it is ready.
  19. Nineapathy
    Donut Mar 20, 2020
    Nineapathy , Mar 20, 2020 :
    Brilliant update mate. Thank Goodness the call dialling notification bug has gone. Look forward to Android 10 update.
    Qwert Luiop likes this.
  20. UzumakiNaruto91
    Donut Mar 20, 2020
    UzumakiNaruto91 , Mar 20, 2020 :
    Auto brightness not working for me after this update.. I have to set it manually now.. anyone else facing this issue?
