126
OxygenOS 9.0.11 OTA for the OnePlus 5 and OnePlus 5T
  1. ninja123456 , via OnePlus 5 Midnight Black , Apr 3, 2020 :
    yeah maybe. for all we know half of Chinese are cremated already. But there's always custom roms available
  2. iharshjjain
    Ice Cream Sandwich Apr 3, 2020
    iharshjjain , Apr 3, 2020 :
    its anytime due now.. may be after the new phone arrives.. fingers crossed.
  3. joncharmed93
    Gingerbread Apr 3, 2020
    joncharmed93 , via OnePlus 5 , Apr 3, 2020 :
    I have the same thing on my OnePlus 5, been happening since the beta ended and I moved to stable. Honestly don't know if it's software or hardware, but I'm hoping to get a new phone soon. Most likely iPhone.
  4. joncharmed93
    True, but I don't really use those much.
  5. zer0se7en
    zer0se7en , via OnePlus 5T , Apr 3, 2020 :
    It's an aging device. it's just natural. Take time on deleting junk files atleast once every month so you won't experience that often. It's what I do. And it helps a lot.
    I use Clean Master to do the job. But ofcourse I have to turn of some sketchy features of that app in order for it to serve me well.
  6. zer0se7en
    Yes it is coincidental. But haven't you considered that perhaps the device was just getting old or worn out? I has already served its purpose for 2yrs or more hasn't it?
    My 5T is doing fine with the update. And also now unrooted. The only problem beginning to arise is the battery drains faster. Which is understandale coz like what I said earlier, the device is getting old and its battery must probably been worn out. Still having 5hrs SoT though. When it was newer it gets to 8hrs+ SoT.
  7. zer0se7en
    Yes it is coincidental. But haven't you considered that perhaps the device was just getting old or worn out? It has already served its purpose for 2yrs or more hasn't it?
  8. I1512995593131
    Froyo Apr 3, 2020
    I1512995593131 , Apr 3, 2020 :
    Go to setting... Apps... Google... Clear all data and it will work.
  9. HalCapone
    Honeycomb Apr 3, 2020
    HalCapone , Apr 3, 2020 :
    It will start to close again after a while even doing this.
  10. Rohan_S_P
  11. HalCapone
  12. Rohan_S_P
  13. arun_n_t2
    Eclair Apr 3, 2020
    arun_n_t2 , via OnePlus 5 , Apr 3, 2020 :
    anyone facing finger print sensor not working as expected as before ?
    for me failing a lot and it's not working while in call☹️
    anandsiddharth likes this.
  14. ninja123456 , via OnePlus 5 Midnight Black , Apr 3, 2020 :
    yeah. fingerprint sensor doesn't work properly after the device goes to sleep.
  15. Pierre02
    Pierre02 , Apr 3, 2020 :
    My fingerprint is as quick as it was just extracted from the box
  16. paulomodesto
    Jelly Bean Apr 3, 2020
    paulomodesto , via OnePlus 5T , Apr 3, 2020 :
    Two years old, is an old device?
    This behavior started since first Android Pie official rom and it wasn't fixed so far.
    anandsiddharth and gopalan_md19 like this.
  17. Mr_Cyrox
    KitKat Apr 3, 2020
    Mr_Cyrox , Apr 3, 2020 :
    And I still find this bizzare
    I have not experienced any major stuttering or other lag that I could not fix since the first Pie open beta till today
    Sure there are some random hickups but easy fixable by just turning off and on the display (weird fix but it works)
    jontalk and zer0se7en like this.
  18. paulomodesto
    I only manage to fix the stuttering by rebooting the Smartphone, and it will work ok for next hours or sometime days.
    It's a very unpleasant feeling when it happen.
  19. zer0se7en
    zer0se7en , via OnePlus 7T , Apr 3, 2020 :
    Me neither. My 5T rarely hiccuos. Maybe atleast once or twice a week. Nothing major that I should validly complain about.
