125
OxygenOS 9.0.11 OTA for the OnePlus 5 and OnePlus 5T
  1. joncharmed93
    Gingerbread Apr 3, 2020
    joncharmed93 , via OnePlus 5 , Apr 3, 2020 :
    Buy a new phone
  2. gopalan_md19
    gopalan_md19 , via OnePlus 5T , Apr 3, 2020 :
    what I have noticed is that the open beta for 6/6T should have ended at Oct 2019..but they are still going on and while on other hand they intensionally delayaed 5T updates
  3. Q1532502274128
    Cupcake Apr 3, 2020
    Q1532502274128 , via OnePlus 5T , Apr 3, 2020 :
    when we got android 10 update in our oneplus5t devices why they are taking too much time for this?? plzz don't delay this OnePlus do it as soon as possible
  4. Waveform Modifier
    Marshmallow Apr 3, 2020
    Waveform Modifier , Apr 3, 2020 :
    https://forums.oneplus.com/threads/...-and-oneplus-5t.1199275/page-39#post-21452824
  5. jontalk
    Honeycomb Apr 3, 2020
    jontalk , Apr 3, 2020 :
    I've had a similar experience with my 5T as well. However the hiccups I've experienced are related to the Smart WiFi (auto-connect) feature and Sound settings. Both issues began after 9.0.8..the WiFi is intermittent or just slow to find a saved network. The Default sound rings no matter whether SMS or other notifications and I'm unable find a way to correct it. Otherwise, battery life is great, no lag, or other problems like many that post here. That said, my phone is lean and mean with maybe 20 additional apps to stock; no social media, games or odd utilities.
  6. JMS74
    Eclair Apr 3, 2020
    JMS74 , via OnePlus 5 , Apr 3, 2020 :
    this update ruined my Bluetooth connection to the xiaomi redmi airdots. outside even if I got them close to the chest / arm they are constantly failing like playing one second at time.
    they used to work kind of ok way way better than now.
    I had 2 updated behind and was delaying 2 updates and now I can't use the airdots. this happen to anyone else?
    how can I revert to 2 past updates ? just download and install them?
  7. Silver_
    Gingerbread Apr 4, 2020
  8. ninja123456
    Ice Cream Sandwich Apr 4, 2020
    LizardSnake76 likes this.
  9. sam82
    Cupcake Apr 4, 2020
    sam82 , via OnePlus 5T , Apr 4, 2020 :
    call lag issue is resolved.but now i got battery drain issue and google search wiget on home screen is not responding.
  10. paulomodesto
  11. gopalan_md19
  12. carloraudino
    Eclair Apr 4, 2020
  13. Waveform Modifier
    Marshmallow Apr 4, 2020
    Waveform Modifier , Apr 4, 2020 :
    Pretty sure it's one of those stupid health apps you downloaded. That's the case for 99.995% of the time. Guaranteed not the up date's fault.
  14. carloraudino
    Eclair Apr 4, 2020
  15. Waveform Modifier
    Still pretty sure it's one of your apps. Go check.
  16. carloraudino
    Eclair Apr 4, 2020
  17. Waveform Modifier
  18. LizardSnake76
    Froyo Apr 4, 2020
    LizardSnake76 , Apr 4, 2020 :
    Tasker can do it if it's set to reliable alarms. If you have it, uncheck that option if the notification bothers you.
  19. M1513606883366
    Froyo Apr 5, 2020
  20. dassnikhil
    Cupcake Apr 5, 2020
    dassnikhil , via OnePlus 5 , Apr 5, 2020 :
    I had the same issue, but when I changed the slider settings (ring, vibrate, silent) observed these details came back and are still there. Try if it work for you.
