414
OxygenOS 9.0.12 OTA for the OnePlus 6T and OxygenOS 9.0.4 OTA for the OnePlus 6
  1. ngydat KitKat Mar 18, 2019
    ngydat, Mar 18, 2019 :
    (Don't take it personally. It's just that your statement was the perfect opportunity to insert this gif :D)
  2. Gzzzy Cupcake Mar 18, 2019
    Gzzzy, Mar 18, 2019 :
    After updating to 9.0.4, 3-4% battery draining overnight please how to fix it
  3. Navin100 Froyo Mar 18, 2019
    Navin100, Mar 18, 2019 :
    Not just overnight it's draining alot simply both day and night oneplus just ****** up with this update
  4. drl431 KitKat Mar 18, 2019
    drl431, Mar 18, 2019 :
    In my experience, with 4 months on an OP6, 9.0.4 was slightly better than 9.0.3, which was slightly better than 9.0.2. Maybe you have some junk apps running in the background such as memory cleaners/boosters, battery monitor, etc. Or social media app settings that are syncing too frequently to their servers. Also, charge your phone overnight, at least occasionally, to allow the system to recalibrate for battery usage.
  5. Amarjeet Sahoo Gingerbread Mar 18, 2019
    Amarjeet Sahoo, Mar 18, 2019 :
    Hi.. Did you get the screenshots of your battery stats?
  6. Gzzzy Cupcake Mar 18, 2019
    Is it okay to charge phone overnight?
  7. drl431 KitKat Mar 18, 2019
    Maybe 30 years ago, that would have been a concern. If you watch the charging rate on your phone, you will notice it gets reduced (slower and phone is less warm) as it approaches 90% and stops at 100%. Then if the phone remains plugged in and unused or moved, it does its maintenance.
  8. Navin100 Froyo Mar 18, 2019
    I don't use any junk apps and I don't even have facebook app too i used to get very good battery on 9.0.3 compared to 9.0.4 I don't use any memory cleaner or battery monitor apps coz I know those apps are junk it's the update issue everyone are complaining about it also so OnePlus shud fix it ASAP
  9. nitishkhullar1187 Honeycomb Mar 18, 2019
    nitishkhullar1187, Mar 18, 2019 :
    OnePlus 6 User:
    For those complaining of battery drain over night, try switching of location services when not required.
    Usually some apps turn them on when required.
    After this update I see that location service is one of the draining elements......
    Rest I have squeezed 7.5 hrs of SOT on this update.
    For example currently I have arnd 5hrs of SOT, with 40% still remaining...... have been watching YouTube and surfing net looking for Bluetooth headphones amps for my 6 while traveling from Delhi to Chandigarh.
    Always remember nothing is perfect not even me n U who keep complaining... Though OnePlus has created a near perfect phone. I especially love holding it without any covers, the finish nd feel is just pure pleasure.
  10. jp4lm Froyo Mar 18, 2019
    jp4lm, Mar 18, 2019 :
    Put your phone on flight mode at night like I do, everyone needs sleep. Battery life is not the best on op6 that I agree on though.
    GMitra likes this.
  11. drl431 KitKat Mar 18, 2019
    I just use the scheduled power on/off function from 12:30 to 5:30 so its automatic and provides the benefit of a fresh restart every day.
    buntycubal and RengelG8 like this.
  12. Deactivated User Mar 18, 2019
    Deactivated User, Mar 18, 2019 :
    Can we have deep integration with RCS & ViLTE instead of using Google Duo within the OnePlus Dialer. Thanks.
    snke and f00tbaLL like this.
  13. viciovb Gingerbread Mar 18, 2019
    viciovb, Mar 18, 2019 :
    I've been noticing more battery life since I stopped charging my phone overnight
  14. Navin100 Froyo Mar 18, 2019
    Show Ur usage too I really don't use location atal on my phone I agree if u use location it will drain but I don't use it atal I have the same apps before update and after update I never installed any new app again so I'm 100% sure it's update issue
  15. nitishkhullar1187 Honeycomb Mar 18, 2019
    then must be having some third party management apps..... how many Sims u using....... and wats ur average SOT??
  16. nitishkhullar1187 Honeycomb Mar 18, 2019
    u don't use location agreed, but does it remain ON or Off from drop down menu.??
  17. chazey2 Ice Cream Sandwich Mar 18, 2019
    chazey2, Mar 18, 2019 :
    Battery, Battery and Battery it's all I read. I have a smartphone! I use it ! I don't turn off restrict anything. I use all day at work including to and from. I'm connected to a Jabra talk 45 the whole time Bluetooth. I average 3-4 hours sometimes more separate all length calls per day. I have two sims, WiFi, location on from the minute it's unplugged and for long periods data running. I chuck it on charge around 7 pm every night for an hour, the next night at 7pm I have usually just over 50% remaining on battery.
    What more can anyone need!
  18. Alexc292 Froyo Mar 18, 2019
    Alexc292, Mar 18, 2019 :
    You're getting late on releasing updates. Huawei phones are rocking the Feb security patch for long. What's going on???
  19. RengelG8 Gingerbread Mar 19, 2019
    drl431 likes this.
  20. RengelG8 Gingerbread Mar 19, 2019
    RengelG8, Mar 19, 2019 :
    I put automatic switch off and on in the night, so my phone sleep about 5 hours during the night and my battery is perfect. normally about 7-8 hours SOT.
    drl431 likes this.
