415
OxygenOS 9.0.12 OTA for the OnePlus 6T and OxygenOS 9.0.4 OTA for the OnePlus 6
  1. Manu Sangeeth
    Froyo Jul 5, 2019
    Manu Sangeeth , Jul 5, 2019 :
    oo. I thought you are on beta version. is that ok to switch to beta.
  2. Dharmendra1987
    Cupcake Jul 5, 2019
  3. Meet_GrimReaper
    Gingerbread Jul 5, 2019
  4. Dharmendra1987
    Cupcake Jul 5, 2019
  5. Rifat10k
    Cupcake Jul 5, 2019
    Parthkansara likes this.
  6. Francesco£
  7. F_Karthikeyan_Thiagaraja
    Cupcake Jul 10, 2019
    F_Karthikeyan_Thiagaraja , Jul 10, 2019 :
    Hi Good Evening
    I did get the update and after installing the update I am not able to see the screen recording option on my OnePlus 6T can you kindly let me know how to find that out.
    Thank You !!!
  8. Monikagoyal00
    Honeycomb Jul 10, 2019
    Monikagoyal00 , Jul 10, 2019 :
    hey...There is an option of edit your notification bar Icons here..
    you have to click this option and This will show you all the icons of your drop down window..
    when u click that option..this window shows u..and here is the option of screen recorder..U have to drag that option from here to ur drop down options....
  9. A1550387522048
    A1550387522048 , Jul 10, 2019 :
    Hi.At the right corner of the bottom on screen there is a body figure to reach accessibility functions. In the second page find screen record function.
  10. F_Karthikeyan_Thiagaraja
    Thank You So Much !!!
    P1530359471032 likes this.
  11. shaner243
    Cupcake Jul 31, 2019
    shaner243 , Jul 31, 2019 :
    I am on open Beta version. It couldn't be the red cable because, when I plug the cord into my computer. It doesnt have the same issue
  12. D1541096176232
    Donut Aug 2, 2019
  13. Meet_GrimReaper
    Gingerbread Aug 2, 2019
    Meet_GrimReaper , Aug 2, 2019 :
    yes it support without any hassle
  14. D1541096176232
    Donut Aug 2, 2019
  15. L1535879402668
    Gingerbread Oct 6, 2019
  16. Auristic
    Lollipop Oct 6, 2019
    Auristic , Oct 6, 2019 :
    There's never been any global battery issues on 6 only local ones.
    Post at https://forums.oneplus.com/threads/...stats-sot-how-to-improve-battery-life.837232/ and try to solve YOUR local issue following advices you'll find there.
    Please don't tell me that you know it's not your apps fault, that you've done everything to sort it out (which is obviously untrue because you still have the problem) or to f*** off (thanks for that advice but I won't) as there is ONLY two alternatives to your problem:
    - Software => you're in charge
    - Hardware => OP's service center is the solution.
    Artemus. likes this.
  17. W1550074178277
    Cupcake Mar 7, 2020
    RBHAMBHU likes this.
  18. Artemus.
    Community Hero 2020 Mar 7, 2020
    Artemus. , Mar 7, 2020 :
    You're talking to other OP owners, there's no devs here.
    W1550074178277 likes this.
  19. MAHEDI HASSAN (F.M)
    Honeycomb Mar 7, 2020
