415
OxygenOS 9.0.12 OTA for the OnePlus 6T and OxygenOS 9.0.4 OTA for the OnePlus 6
  1. AdemJ
    Eclair Feb 12, 2019
    AdemJ , Feb 12, 2019 :
    In that case you need to change the app Duo as a default app, So Go to App & Notification and search for Duo after check it if it is like the photos which I have sent.
  2. B.J.R.G
    Honeycomb Feb 12, 2019
    B.J.R.G , Feb 12, 2019 :
    You can make a call directly from your contact list if that person is available on Duo.
    Also, it shows in your call log list.
  3. OzanGuemueskuyu
    Froyo Feb 12, 2019
    OzanGuemueskuyu , Feb 12, 2019 :
    I checked it and the settings are the same like yours...
    I saw that you have a different version of Duo.
    Maybe that's the problem?
  4. B.J.R.G
  5. Dunnow
    The Lab - OnePlus 6 Reviewer Feb 12, 2019
    Dunnow , Feb 12, 2019 :
    I don't use google duo, what does deep integration with it mean?
  6. Raghav_Dus
    Cupcake Feb 12, 2019
  7. lewiatanx
  8. bkgopi11
    Eclair Feb 12, 2019
  9. F_Κωνσταντίνος_Αηδόνης_I , Feb 12, 2019 :
    The irony is that they are asking people for an upcoming feature on oxygen OS but they can't release beta features in a 2 month period? And other features that got lost in previous beta. Just saying , I am not dissatisfied from op6 but seeing their hunger for success , regular fast updates is one of their boosts and I think they should work harder for that!
  10. akuluki
    Donut Feb 12, 2019
  11. Kostas filippou
  12. Draculablood
    Donut Feb 12, 2019
  13. Rafail Panteli
    Eclair Feb 12, 2019
  14. Zaphodrocks
    Ice Cream Sandwich Feb 12, 2019
    Zaphodrocks , Feb 12, 2019 :
    Close Chrome, the force stop it and the issue will go away.
    M1549921126378 likes this.
  15. M1549921126378
    M1549921126378 , Feb 12, 2019 :
    i have found another solution to the problem... i use firefox lite and there are no issues with it... But thanks for the suggestion
  16. rik_mav
    Froyo Feb 12, 2019
    rik_mav , Feb 12, 2019 :
    True, buh that was before this new update. let's give this new update a chance.
    However, if it reoccurs, we report the bug via the recommended channels.
    cozzmat likes this.
  17. ngydat
    Lollipop Feb 12, 2019
    ngydat , Feb 12, 2019 :
    Now, you don't have to open Google Duo to video call someone. You can do it directly with the phone app (assuming that you and the person you're trying to reach have Google Duo installed)
    Dunnow likes this.
  18. broodrooster
    Gingerbread Feb 12, 2019
    broodrooster , Feb 12, 2019 :
    thank you Manu for your updated software update
    nothing weird to mention till now after update.
  19. R1547222595964
    Froyo Feb 12, 2019
    R1547222595964 , Feb 12, 2019 :
    Has the problem with unlock screen been solved? I have 2 OP6t, and since last update unable to Single(or double) tap and wake fingerprint unlock section, I have to move the phone a bit then it appears
