260
OxygenOS 9.0.13 OTA for the OnePlus 6T and OxygenOS 9.0.5 OTA for the OnePlus 6
  1. M Mihai Tudor
    Froyo May 16, 2019
    M Mihai Tudor , May 16, 2019 :
    This is one of the procedures:
    1. Open Dialer
    2. type USSD code *#*#4636#*#*
    3. Select phone information
    4. Now select Network type *LTE/UMTS auto(PRL)
    5. Reboot..
    6. Done
    Check if both phones use the same Network type settings.
    If they don't, try to set the one that doesn't work the same as the one that does...
    Continue changing and rebooting until you find the perfect settings.
  2. ojasviakku
    Eclair May 16, 2019
    ojasviakku , May 16, 2019 :
    Both have volte enabled. 6t have 4g on both sim enabled
  3. M Mihai Tudor
    Froyo May 16, 2019
    Read this and adapt it for yourself, maybe it helps:
    https://forum.xda-developers.com/oneplus-5t/how-to/guide-volte-vowifi-german-carriers-t3817542
    Maybe the last update changed some settings... Maybe there is a Sub0 or Sub1 deactivated...
    Use the NO ROOT version.
    I played with these settings until I found the perfect profile for my wife's OP6. It didn't enable VoLTE and VoWIFI out of the box.
  4. M Mihai Tudor
    Froyo May 16, 2019
    They both have the same settings?
    example: Network type *LTE/UMTS auto(PRL)
  5. ojasviakku
    Eclair May 16, 2019
    Yup
  6. M Mihai Tudor
    Froyo May 16, 2019
    I played with this also since my first smartphone. Some settings work only for some phones.
    If you have the wrong Network type selected, it can also show that you have signal, but can't send/receive sms or call...
    It can also drop signal... It can also stay on 3G, instead of 4G...etc...
  7. abasald1
    Cupcake May 16, 2019
    abasald1 , May 16, 2019 :
    is this update on software? will it do it automatically for one plus 6T users?
  8. M Mihai Tudor
    Froyo May 16, 2019
    This doesn't mean that they both work on the same settings...
    My wife's OP6 has TD-SCDMA/CDMA/UMTS ...
    LTE/UMTS auto(PRL) - drops signal and doesn't work for her...
  9. M Mihai Tudor
    Froyo May 16, 2019
    As I told you before... play with the settings, restart... until you find the perfect settings.
    It's your phone and you need it to work.
    Write down every step you make, so that you don't forget...
  10. abasald1
    cool thanks! I'm so grateful I have not experienced anything negative with my one plus 6T device since I purchased it. [e]1f64c[/e] I love it!!
  11. ojasviakku
    Eclair May 17, 2019
    ojasviakku , May 17, 2019 :
    Tried everything... But nothing is working. Voice breaks alot while calling!
  12. Flamingskull9
    Froyo May 17, 2019
    Flamingskull9 , May 17, 2019 :
    I guess every phone can't behave the same way. Was getting a SOT of around 4 hours on all previous builds. It improved massively to 6 hours on 9.0.4. And now is back to the 4 hour mark with 9.0.5. Been using the phone for nearly a year now so I know what I'm saying and my phone usage has been consistent throughout.
  13. ilesh chainani
    Froyo May 17, 2019
    ilesh chainani , May 17, 2019 :
    yes its completely depends on usage if someone play game for continue it would get 4.5 to 5.9 hour SOT and in moderate situation it will be 5.5 to 6.8 hour SOT
  14. edy90s
    Honeycomb May 17, 2019
    edy90s , May 17, 2019 :
    i get 3 , without playing, only social apps . it's horrible for me. I preform factory reset I don't know which drain my battery.
    robin143 likes this.
  15. guywong
    Froyo May 18, 2019
    guywong , May 18, 2019 :
    T-Mobile variant users often complain that they get slow update. But I just saw this article that T-Mobile is rolling out a new stable update with April security patch. I know we can get the Beta ROM with newer than the March security patch and I know some people don't think security patches are that important. Still amazing that T-Mobile can do that while OnePlus can't. Don't get me wrong. The 6T is my 3rd OnePlus phone, I have the One and a 3T, and I am not complaining here.
    https://www.tmonews.com/2019/05/t-mobile-oneplus-6t-security-update/
  16. ilesh chainani
    Froyo May 18, 2019
    ilesh chainani , May 18, 2019 :
    ohh then its really scary please contact ONEPLUS or leave them a feedback or report the problem your facing in community app
  17. RengelG8
    Gingerbread May 18, 2019
    dany973 likes this.
  18. G_Mr_....
    Jelly Bean May 19, 2019
  19. Auxqii
    Honeycomb May 19, 2019
    Auxqii , May 19, 2019 :
    It's a meme.
  20. G_Mr_....
    G_Mr_.... , May 19, 2019 :
    Yeah I know, the words still have the same meaning what it says on the meme, I'm just stating a fact to anyone that trust's a company, not specifically for this meme.
    [e]1f44d[/e]
    Kytharsis likes this.
