260
OxygenOS 9.0.13 OTA for the OnePlus 6T and OxygenOS 9.0.5 OTA for the OnePlus 6
  1. MAHEDI HASSAN (F.M)
    Honeycomb Apr 23, 2019
    MAHEDI HASSAN (F.M) , Apr 23, 2019 :
    C1529673532320
    don't updates please
    after this play store are not working​
    its a specific problem, it's is not overall problem.
    clear the storage data of play store. clear cache memory., reboot your device.
  2. robin143
    robin143 , Apr 23, 2019 :
    Facing over heating issues after i updated my OP-6 to 9.0.5.... done clear cache and factory reset
  3. tortoise14
    tortoise14 , Apr 23, 2019 :
    No such problem 4 me
  4. MAHEDI HASSAN (F.M)
    please specify when you face it.
  5. C1529673532320
    Cupcake Apr 23, 2019
  6. robin143
    While normal usage... Not while gaming
  7. C1529673532320
    C1529673532320 , Apr 23, 2019 :
    why rebute phone is new
    just purchased 50 days ago , no extra application are loaded
    then this type of thing required.
    if we are using latest processer , 8 GB ram.
    then why.
  8. C1529673532320
  9. MAHEDI HASSAN (F.M)
    when gaming heating issue is normal.
    today s some third party app fall pressure on cpu and it's become hot.
    but using normal condition and mobile continuously heating its a problem.
    please check your app that which applications running continuously on ram. clear them...
    go settings turn on developer options then go to the memory...
  10. kepitsimple
  11. pankys143
    pankys143 , Apr 23, 2019 :
    last time I send query regarding calling functionalities and contacts
    but one plus disappointed once again no any update ..
  12. B_Wrath
    Marshmallow Apr 23, 2019
    B_Wrath , Apr 23, 2019 :
    Why do you need zram when you have 8GB of ram?
    ironass and sushant1821987 like this.
  13. sushant1821987
    Eclair Apr 23, 2019
    sushant1821987 , Apr 23, 2019 :
    u meen it's swapped memory that use like page file in windows systems that uses some space from storage?
  14. MobinPathan
    MobinPathan , Apr 23, 2019 :
    disappointed from OnePlus ....Now I mostly preferred MI mobile phones because it's have many features which is not present in OnePlus ....and Mi update is also good
  15. B_Wrath
    There is no swap partition in Android to use zswap function. Zram was initially used in low ram devices just to compress the activities and also to create addition ram space.
    Auristic likes this.
  16. ironass
    Lollipop Apr 23, 2019
    ironass , Apr 23, 2019 :
    Good question B_Wrath!
    I and others, have disabled ZRAM on Open Beta as it is causing battery drain and lags.
    B_Wrath likes this.
  17. B_Wrath
    I just don't understand why they implemented zram in beta. It's not like it was needed. All my apps hold on irrespective of the time.
    ironass likes this.
  18. T1556040279633
    T1556040279633 , Apr 23, 2019 :
    Will they add a HBM mode or simply just increase screen brightness?? This telephone cant be seen on direct sunny light!!!!
  19. sushant1821987
    Eclair Apr 23, 2019
    ok got it thanks
  20. ironass
    Agreed. I currently have 31 apps open in the background and 2.5GB of 8GB RAM, free. IMHO, there is no need for ZRAM which has been draining battery by around 15%-20% and taxing the CPU.
