260
OxygenOS 9.0.13 OTA for the OnePlus 6T and OxygenOS 9.0.5 OTA for the OnePlus 6
  1. B_Wrath Marshmallow Apr 24, 2019
    B_Wrath, Apr 24, 2019 :
    Just charge it once overnight while it is turned on.
    Xnatty likes this.
  2. Xnatty Honeycomb Apr 24, 2019
    Xnatty, Apr 24, 2019 :
    wow I can't imagine waiting another 2 month with this update, my battery life cycle will decrease faster than I've been trying to extend it's life. hence it will decrease the battery life cycle due to draining fast and which leads to charging it again and again which Everytime leads to decrease in the battery mah/life cycle. we need a hotfix ASAP!
  3. Xnatty Honeycomb Apr 24, 2019
    ok, hope it works
  4. B_Wrath Marshmallow Apr 24, 2019
    There is no need. Charge it overnight while it is on.
  5. dragoscorodeanu Gingerbread Apr 24, 2019
    dragoscorodeanu, Apr 24, 2019 :
    Something like this?
  6. Xnatty Honeycomb Apr 24, 2019
    dragoscorodeanu likes this.
  7. dragoscorodeanu Gingerbread Apr 24, 2019
    And nope, I haven't used the damn app for 6h. I used it for maximum 10 minutes after the update was installed. Gboard is active for 9 hours in background.
  8. G_Kirk_Fontaine_MBlG Eclair Apr 24, 2019
  9. Xnatty Honeycomb Apr 24, 2019
    2 new spikes and weird behavior I've been seeing is my telegram and Gboard are on fire after the update like as if the system doesn't optimize them
    also I use the 20-80% charging method which was amazing on 9.0.12 with full day + another half day usage. now it's 5pm (17:34) and I'm at 16% which is so much unstable
  10. G_Kirk_Fontaine_MBlG Eclair Apr 24, 2019
    G_Kirk_Fontaine_MBlG, Apr 24, 2019 :
    especially since one plus 7 release date is coming
    May 14
    Xnatty likes this.
  11. Xnatty Honeycomb Apr 24, 2019
    May 14​
    let's try charging it all night as @B_Wrath suggested, but don't do it more than one time cause even one time is bad enough for the technology which stops charging ur phone when it gets 100 and goes on.. 99-100-99-100 all night, it's very bad for the phones battery life cycle but I would do anything to have my old 9.0.12 battery life back. so let's try what b-wrath said and meet back here tomorrow same time to see if it works or no
  12. N1556116989142 Cupcake Apr 24, 2019
  13. Andreas Rauchhaus Eclair Apr 24, 2019
    Andreas Rauchhaus, Apr 24, 2019 :
    So here's the report about the first days on 9.0.13. Battery lasts as usual. Two days most time with WLAN costs approx. 50% battery. My usage was typically for that period.
    Actually there is no difference in battery usage from the previous 9.0.12 version.
    ironass and Auristic like this.
  14. avinash@10 Gingerbread Apr 24, 2019
    avinash@10, Apr 24, 2019 :
    First of all it is too late for this update to come. OP should have given this in March itself , why they kept us waiting for so long !! This update has only the security patch level and some general bug fixes, we had expected more , as OP was taking time, so we thought that something innovative will be there. I hope OP will do something better next time.
    G_Kirk_Fontaine_MBlG likes this.
  15. jmarks Honeycomb Apr 24, 2019
  16. A1550387522048 Gingerbread Apr 24, 2019
    A1550387522048, Apr 24, 2019 :
    I totally agree with you. I really do not think to change my OP6 with any other. Pls take a look at APK mirror.com to update stock cam to 3.0.32 or 36. I found this update best of OnePlus..
  17. Soumya_Basu_1682 Cupcake Apr 24, 2019
    Soumya_Basu_1682, Apr 24, 2019 :
    After the update phone is not working as expected. the mobile data is not functioning. not able to run the net properly. what is happening?
  18. chandertalreja Gingerbread Apr 24, 2019
    chandertalreja, Apr 24, 2019 :
    Hi @Manu.J,
    Ive been repeatedly raising this annoying contacts bug since my oneplus 3. it was fixed then after i reported it and now its back on my oneplus 6 since the PIE update.i raised a ticket, i spoke to a Bobby.D but he could not understand the issue. please do look into this & respond back so i atleast know this is being looked into sir.
    My bug repot : https://forums.oneplus.com/threads/...s-not-duplicate-but-probably-link-bug.966928/
    I submitted a bug report, provided Bobby.D with a screenshot from a facebook groups page with people acknowledging the same issue as well but there has been no progress.
    A log cannot be provided since its a basic replication bug and does not really require log and is very easy to reproduce.
    1-open dialer
    2-open dialer pad and key in any contact using quick dial ( this contact shud have whatsapp too )
    3- after u have done that, u shud see results on top ( refer to the screenshot i have attached )
    4- just below the persons name u shud see the number, there will be same number showing up twice right below the contact name.
    note : this does not happen in contacts APP.
    use the inbuilt dialer(phone) app and use the numeric keypad.
  19. A1554871375196 Donut Apr 24, 2019
    A1554871375196, Apr 24, 2019 :
    I'm using the OnePlus 6T since Dec, 2018 and I never faced ang major issues but the only thing that irritates me is the brightness level in OnePlus 6T. One of my friend is also a OnePlus user and he has OnePlus 5T but his brightness level way more than mine, although I know after an update their brightness level also came down to the same rate as OnePlus 6T. So, I suggest OnePlus Team to please try and fix this brightness level issue as it is difficult to view our mobile screen without a full brightness level that drains the battery faster.
  20. Shajahankm Gingerbread Apr 24, 2019
