260
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. ashu_thakur06 Cupcake Jun 11, 2019
    Helder_DAlmeida likes this.
  2. Helder_DAlmeida Gingerbread Jun 11, 2019
    danycmoi and ashu_thakur06 like this.
  3. Ludovic_Mallet Cupcake Jun 11, 2019
  4. ashu_thakur06 Cupcake Jun 11, 2019
    ashu_thakur06, Jun 11, 2019 :
    then what is the normal battery life, please let me know
  5. ngydat KitKat Jun 11, 2019
  6. ngydat KitKat Jun 11, 2019
    ngydat, Jun 11, 2019 :
    Uh 7 hours and a half of screen-on time is good. How is that bad ?
    ironass and danycmoi like this.
  7. Ludovic_Mallet Cupcake Jun 11, 2019
    Ludovic_Mallet, Jun 11, 2019 :
    before the update I got 3 sometime 4 days of battery. now I have one day and a half maximum. even if I leave it at home doing nothing.
    I haven't changed anything
  8. ngydat KitKat Jun 11, 2019
    Maybe you have a bad battery life but @ashu_thakur06 was asking for him. It doesn't necessarily mean that all the users are in the same situation as yours.
  9. U1559910066679 Cupcake Jun 11, 2019
    U1559910066679, Jun 11, 2019 :
    Can someone explain to me why I need a vpn for a simple update? Its my first oneplus switching from Huawei so I'd assume updates are standard but why the vpn?
  10. ngydat KitKat Jun 11, 2019
    You only need the vpn if you're impatient to have the update
    drl431 and ironass like this.
  11. U1559910066679 Cupcake Jun 11, 2019
    That doesn't make any sense because it says the update is ready, press download and it sits at 0% and does nothing then says something went wrong. So why publish an update if it doesn't work. Smart ***
  12. ngydat KitKat Jun 11, 2019
    You do realise that you're not talking to any member of the One Plus staff, don't you ?
    Also, I wasn't being sarcastic or rude when I told you
    People who want to have the update faster use the VPN because from time to time, updates are deployed region by region.
    Also, insulting me won't help your case
  13. Santiago Romero Cupcake Jun 11, 2019
    Santiago Romero, Jun 11, 2019 :
    This update got me a lot of issues with the Bluetooth, my songs were interrupted every second. Check it out PLEASE!
  14. U1559910066679 Cupcake Jun 11, 2019
    I understand that but your first comment felt irrelevant and did not help me at all just by calling me impatient, you should've started with your second comment and explaining it. Perhaps lead with that next time and you might get a better result. Sorry for being so rude :)
  15. ngydat KitKat Jun 11, 2019
    Glad that we were able to work this one out
  16. Yannis Neris Ice Cream Sandwich Jun 11, 2019
    ironass likes this.
  17. G_XJonathanX_co Froyo Jun 11, 2019
    G_XJonathanX_co, Jun 11, 2019 :
    Which device are you using?
  18. G_XJonathanX_co Froyo Jun 11, 2019
    If a VPN. doesn't work for you, you can download the incremental files, here:
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...ygen_22_OTA_031_all_1905281326_9562bbe097.zip
    ONEPLUS 6T
    https://otafsg1.h2os.com/patch/amaz...ygen_34_OTA_020-021_patch_1905281358_06f0.zip
    You know how the game works right? Install with the local upgrade and you'll be done.
  19. U1559910066679 Cupcake Jun 11, 2019
    I appreciate your feedback. My vpn works and I got the update installed easily. But my concern was why I would need a vpn for a simple security update when it's a standard thing on other devices. My Huawei would do it automatically. But when I tried installing the update on my oneplus 6t it was stuck on 0% and just kept coming up sorry something went wrong. But maybe it's a standard thing for I plus models? That I need to switch on a vpn for updates now?
  20. G_XJonathanX_co Froyo Jun 11, 2019
    U1559910066679
    I appreciate your feedback. My vpn works and I got the update installed easily. But my concern was why I would need a vpn for a simple security update when it's a standard thing on other devices. My Huawei would do it automatically. But when I tried installing the update on my oneplus 6t it was stuck on 0% and just kept coming up sorry something went wrong. But maybe it's a standard thing for I plus models? That I need to switch on a vpn for updates now?​
    Sorry, I don't know why, I would've been lying to you if I tell you. Maybe updates don't come out globally as soon as it launches, for example where I live, it took 3 days after release without VPN of course.
