261
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. U1559910066679
    Cupcake Jun 11, 2019
    U1559910066679 , Jun 11, 2019 :
    Cheers mate, I've had the update since it came out like a week or 2 so was just wondering why my friend just said download vpn. I'm in Dubai so maybe yeah something to do with the region. Thanks for the help!
  2. N1544725203334
  3. Isaiahec
    Isaiahec , Jun 11, 2019 :
    With this update my Bluetooth stability got horrible. It chops up and cuts out randomly on both earbuds sometimes the left sometimes the right. I've never had this issue before the update. Is there any way to revert?
  4. G_XJonathanX_co
    Froyo Jun 11, 2019
    G_XJonathanX_co , Jun 11, 2019 :
    You're welcome!
  5. K1527946065528
    K1527946065528 , Jun 11, 2019 :
    after the update voice calls having high volume even in min.... works like loud speaker.... irritated...(.oneplus6)
  6. Malendo
    Donut Jun 11, 2019
    Malendo , Jun 11, 2019 :
    Raw is a file format (raw data format), similar to jpg. It is lossless, so perfect for editing, e.g. in Photoshop.
    Helder_DAlmeida likes this.
  7. drl431
    Lollipop Jun 11, 2019
    drl431 , Jun 11, 2019 :
    To roll-back, be prepared to have all data wiped. Then go to the pinned open beta thread and read post #6. That post has links for special roll-back zip (rom) files that would get you back to the previous stable OS.
    Kytharsis likes this.
  8. U1541028781289
    U1541028781289 , Jun 11, 2019 :
    I'm really disappointed with how the 6T is being 'supported'. The 7 Pro just got this big camera upgrade, and yet the 6T since launch has never received any major updates. Only minor updates with no significant improvements to the camera or Oxygen OS software. The 6T also needs a camera boost as well as the software is primarily the issue. I'm guessing this will also happen to the 7 Pro in a month or two.
    SasaX likes this.
  9. G_Guillaume_Parisot_iySS
  10. drl431
    Turn off hearing aid compatibility in the accessibility menu. This is off by default anyway.
    K1527946065528 likes this.
  11. K1527946065528
    thanq
    drl431 likes this.
  12. Kytharsis
    Marshmallow Jun 11, 2019
    Kytharsis , Jun 11, 2019 :
    I have, works just fine.
  13. N1544725203334
  14. U1513813701216
    Gingerbread Jun 11, 2019
  15. ashu_thakur06
  16. Kytharsis
    I1548080976224, ngydat and drl431 like this.
  17. ashu_thakur06
    ashu_thakur06 , Jun 11, 2019 :
    Hmm, okay, but the phone is showing that it might last up to 1:30pm but I'm not using it much prior to the update it used to show the approximate time of over more than 24 hrs but now it is like 14-16 hrs.
  18. Kytharsis
    That will change all the time based on how you use your phone right then and there. Never trust it.
  19. ashu_thakur06
    Okay, thanks [e]1f60a[/e]
  20. G_Guillaume_Parisot_iySS
