263
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. KuroYami
    Gingerbread Jun 12, 2019
    KuroYami , Jun 12, 2019 :
    Screen Recorder, Zen Mode, Digital Wellbeing, and fnatic Mode all is now up in the OB of 5/5T & 6/6T~~~ u guys can look forward for this update arriving in Stable in the next few months~~ yay
  2. I1548080976224
    Froyo Jun 12, 2019
    I1548080976224 , Jun 12, 2019 :
    And you guys still complaint about battery life ...
    this is from 80 which i got
    it's best i can say and yeah idea drain also gone ...
    so just use phone and forget about battry life ..
    this is for the people who always says after update drain is high ...
    Helder_DAlmeida and KuroYami like this.
  3. KuroYami
    battery drain right after the update often happens, u just need to keep using as it is to retrain the machine learning... after 2-3 charge cycles, it will be back to normal...
    they don't know about the machine learning system in current gen phones, and keep on clearing cache, what they don't know is clearing cache will make matters worse... experienced users had alrdy kept answering to their question "to just leave your phone as it is, and continue using" and yet they still complaining and try useless methods which made things worse... we literally just gave up on answering it as we all know kiddies won't read through previous comments...
  4. I1548080976224
    Froyo Jun 12, 2019
    absolutely right mate ...
    but they don't understand and keep telling about that issue which even not there.
    Helder_DAlmeida likes this.
  5. pramodkumar5123
    Donut Jun 12, 2019
    pramodkumar5123 , Jun 12, 2019 :
    already it is in beta build
  6. ashu_thakur06
    Cupcake Jun 12, 2019
  7. J1555094438736
    J1555094438736 , Jun 12, 2019 :
    Searching any contact from Contacts list and tapping on that contact to dial doesn't work properly and takes 5-6 attempts and lot of time to display the dialing screen. Please let me know how to get rid of this issue?
  8. Sushant_R7
    Eclair Jun 12, 2019
    Sushant_R7 , Jun 12, 2019 :
    launcher fixes available at playstore app update section....check there
  9. DSCharan
    DSCharan , Jun 12, 2019 :
    In market 6tT tempered glass is not available (original frm oneplus)...so 0ne plus 7 screen same size as 6T...one plus 7 tempered glass is ok for 6T
  10. DominicTitus
  11. drl431
    Marshmallow Jun 12, 2019
    drl431 , Jun 12, 2019 :
    That is a reasonable assumption. But I would also expect the packaging to indicate this.
  12. ngydat
    KitKat Jun 12, 2019
    ngydat , Jun 12, 2019 :
    No one did actually
    ilesh chainani likes this.
  13. Q1535835019792
  14. J1555094438736
    anyone else facing this issue?
  15. Android-Andi
    Jelly Bean Jun 12, 2019
  16. androidForever9864
    Honeycomb Jun 12, 2019
    androidForever9864 , Jun 12, 2019 :
    Am I right, that nowadays Android versions to no longer allow to clear cache partition at whole. Instead someone has to manually clear every cache for each App individually?
  17. K1560355037790
  18. drl431
    You can still clear the ART cache in recovery, but unless you have system-wide problems, this is not necessary. Clearing the cache of a problem app would normally suffice.
    @elanglois wrote a very good post relating to this:
    https://forums.oneplus.com/threads/caches-explained.828298/
  19. dhruv.lakhpatia
    Eclair Jun 12, 2019
    dhruv.lakhpatia , Jun 12, 2019 :
    finger print reader not functioning post the latest update on OnePlus 6 device, any one else facing the same issue?
    can i rollback to previous mode?
  20. drl431
    My OP6 fingerprint reader seems fine. You know rolling back requires a full system wipe...
    dhruv.lakhpatia and ironass like this.
