261
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. drl431
    Lollipop Jun 12, 2019
    drl431 , Jun 12, 2019 :
    My OP6 fingerprint reader seems fine. You know rolling back requires a full system wipe...
    dhruv.lakhpatia and ironass like this.
  2. W1559182541065
    Cupcake Jun 12, 2019
    W1559182541065 , Jun 12, 2019 :
    About Phone=>
    Device name= One Plus 6T
    OxygenOS version= 9.0.5
    Model= ONEPLUS A6013
    Yes I am sure that I have One Plus 6T lol
  3. ironass
    KitKat Jun 12, 2019
    ironass , Jun 12, 2019 :
    I guess the reason that @Kytharsis asked that is because you are 7 updates behind the current OnePlus 6T firmware and only 1 update behind the OnePlus 6. Is there any reason that you have not updated 7 times?
    Kytharsis likes this.
  4. dhruv.lakhpatia
    dhruv.lakhpatia , Jun 12, 2019 :
    could you guide me to successfully complete Full system update and are the any pros & come?
  5. ade0410
    Honeycomb Jun 12, 2019
    ade0410 , Jun 12, 2019 :
    so you're going to do this because you say your finger print scanner has stopped working?
    have you rebooted your phone?
    cleared the finger prints and added them again?
    cleaned the finger print scanner?
    never had a single problem with my OP6 finger print scanner either on stable and currently on beta.
    always works first time, every time. fast and smooth. no issues.
    ironass likes this.
  6. dhruv.lakhpatia
    have tried rebooting my phone...
    have also registered my fingerprints as well....
    Neither has i till i last installed the latest stable update...
  7. Ruy_peixoto
    Eclair Jun 12, 2019
    Ruy_peixoto , Jun 12, 2019 :
    gyro is not working. I tried several configuration applications but I have no results. This happened after I upgraded
  8. Ruy_peixoto
    Eclair Jun 12, 2019
    @manuj how to solve? virtual reality does not work, the pupg with gyroscope in sight also does not. boring it. it's all spinning porals that I use app to calibrate
  9. Ruy_peixoto
    Eclair Jun 12, 2019
  10. drl431
    As this is not a known issue and if you have tried to troubleshoot, I would do a factory reset next.
    This would wipe all data also, but leave you with your current OOS, so backup everything.
    Settings > System > Reset options > Erase all data (factory reset).
    If you really want to roll-back, go to the pinned beta thread, read post #6, and use the roll-back zip.
    ironass likes this.
  11. Ajay008
    Froyo Jun 13, 2019
    Ajay008 , Jun 13, 2019 :
    Hello oneplus team,
    I got a problem in camera while taking raw images .....
    I didnt get images that I want.....
    I will add a screen shot of raw and jpeg
    the above one is raw
    the 2 nd is jpeg
    Fix this issue
    binu678 likes this.
  12. Parker Kincaid
    Froyo Jun 13, 2019
    Parker Kincaid , Jun 13, 2019 :
    After seeing issues noted by some users I held off on updating from 9.0.1.3 to 9.0.1.4. I decided to stop holding off on June 10th. Two days later and I've run into no issues.
    OP6T Global with Verizon.
  13. elanglois
    Lollipop Jun 13, 2019
    elanglois , Jun 13, 2019 :
    No. You are not. You have all your caches confused
    The cache partition is basically unused by Android. It no longer exists.
    Clearing your caches from recovery used to clear the above partition and your Dalvik/ART cache. These are two totally different things. You can still clear the ART cache this way, and it's a great way to slow down your phone, heat it up, and reduce battery life.
    The application caches you clear for each app are just cached files like thumbnails and internet data. It's yet a THIRD type. Again, clearing it just makes your phone regenerate it. Like, for example, your Play Store may have some issue and you clear its caches so that the app is forced to get fresh data from the cloud. I rarely bother. I'll just uninstall the app and reinstall it. Nuke the site from orbit, it's the only way to be sure.
    Hydra Bob likes this.
  14. B1546697779375
    Cupcake Jun 13, 2019
    B1546697779375 , Jun 13, 2019 :
    After the recent update to 9.0.14,I am unable to connect to internet on my mobile. There is no signal of 4G on my mobile . Please someone respond...
  15. elanglois
    First, this is the community forums, not the oneplus team
    Second, please stay the hell OUT of Pro mode because you have no clue what you are doing. BOTH pictures are JPG because RAW is not developed into a picture yet. You have to render the data into a JPG to view it on your screen.
    The camera software will render things a specific way and apply processing. Lots of processing. RAW files just have a data dump of all the sensors. The viewfinder is showing a less processed rendition for RAW than the JPG, but its JUST the viewfinder! You don't have an image until you render the raw file to.something else like with Snapseed, Gimp, Adobe, or Photoshop.
  16. elanglois
    Check APN settings
  17. Ajay008
    Froyo Jun 13, 2019
    i know mahnnnn.....i have to edit it to form jpeg
    but The raw image is not clear and sharp as jpeg even after editing
    And I calling oneplus team to correct it and i know they analuse community post to improve perfomance and reduce bugs in updatess
    If you dont know abou this and If u dont know about the pro mode
    Go to hell.......And be quite[e]1f612[/e]
    binu678 likes this.
  18. O1539362690991
    Eclair Jun 13, 2019
  19. F_DrAhmad_Hammady_UObT
    F_DrAhmad_Hammady_UObT , Jun 13, 2019 :
    I installed the update but now I can't make a call
    what is happening????
    please fix it
    I am struggling after installing this update
    the dialing is terrible
    please help
  20. elanglois
    You'll have to be way more descriptive than that. You are the only one having trouble dialing the phone. You push the little numbers and ... ????
