263
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. ilesh chainani
    Froyo Jun 13, 2019
    ilesh chainani , Jun 13, 2019 :
    i dont know why but now a day's Oneplus had no answer about there update with bugs, every update contain bugs .. coming to serious discussion those who are not getting update early please don't go to VPN or download it from links don't do this kind of activities just wait for your regular OTA it will take some time but it better to wait.. why every one is in hurry. Apart of bugs .. when they say they had improve camera lol.. the camera capture worst and blurry images the details which was seen in last update are also not there now we think we did mistake. we shouldn't update this but every update has some feature or security patch so we can't neglect them.. and in this update they introduce one feature called confirmation password UI for hidden space but that was mentioned in community and not in update log in phone so that people can see it in community and as soon they get ota they can update. but now that feature is still not there front camera quality also poor now what you go and buy new oneplus phone lol.
  2. androidForever9864
    Honeycomb Jun 13, 2019
    androidForever9864 , Jun 13, 2019 :
    Yes, but there should be a possibility to clear the cache of a apps with one single gui action. I don't want to encouter all the possible problems with apps, to know for which app the cache should be cleared. It simply makes not sense to let people run in all the various problems, and later tell them, you can fix this by clearing cache of app x or y. It should be done automatically at an system update, or at least been asked at then end, if the user wants to do it.
  3. Helder_DAlmeida
    KitKat Jun 13, 2019
    Helder_DAlmeida , Jun 13, 2019 :
    There is nothing wrong with pics my friend. It's just like that. Now you need to work on raw. "never settle"
    Ajay008 likes this.
  4. drl431
    Marshmallow Jun 13, 2019
    drl431 , Jun 13, 2019 :
    I can not imagine a scenario where I would need or want to clear the cache of every app...
  5. J1527140365700
    Donut Jun 13, 2019
    J1527140365700 , Jun 13, 2019 :
    After the new update,the battery of my OP6 seems to be draining extremely fast. Just 2 hrs of on screen time drains about 60% of the battery and this when I am not playing any games or watching videos. Please fix!!
  6. drl431
    Pubg needs fixing. But it also helps to recalibrate the system for battery usage after an update.
    ironass and Artemus. like this.
  7. J1527140365700
    Donut Jun 13, 2019
    I don't have pubg installed or any game for that matter.
  8. drl431
    Ok, maybe look at how often social media apps are syncing to their servers.
    But still consider system recalibration after an update.
    Artemus. likes this.
  9. J1527140365700
    Donut Jun 13, 2019
    how do I do that?
  10. saaiful
    Donut Jun 13, 2019
    saaiful , Jun 13, 2019 :
    I am using the 6t, and after the latest update it seems like portrait mode is not working in front camera of my camera app. How to fix it? In my Google camera app everything is working.
  11. drl431
    Just charge the phone overnight (powered on).
  12. drl431
    Which version is your OnePlus camera app?
  13. saaiful
    Donut Jun 13, 2019
  14. anupritaisno1
    KitKat Jun 13, 2019
    anupritaisno1 , Jun 13, 2019 :
    Charge your phone overnight while it's turned on
    drl431 likes this.
  15. drl431
    That is an OP7 camera apk that you "side loaded" into an OP6t. That wont work well.
    buntycubal and Artemus. like this.
  16. saaiful
    Donut Jun 13, 2019
    drl431
    That is an OP7 camera apk that you "side loaded" into an OP6t. That wont work well.​
    Where can I find the original app? Also I don't remember updating my stock camera app or replacing it with oneplus 7 camera.
  17. drl431
    Someone did this. Anyway, disable the camera app, tap 3 dots, and remove updates.
    buntycubal, Artemus. and saaiful like this.
  18. saaiful
    Donut Jun 13, 2019
    Thanks for the information. The camera issue resolved.
    drl431 likes this.
  19. drl431
    Great, thanks for the reply!
  20. Iammshahid
    Cupcake Jun 13, 2019
    Iammshahid , Jun 13, 2019 :
    there is an camera issue as it's not working as well as the face unlock ! it states that the camera is been used by other applications . And when normal camera is opened , it automatically closes the application , going back to home screen after the OTA update 9.0.14
