261
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. F_DrAhmad_Hammady_UObT Cupcake Jun 15, 2019
    F_DrAhmad_Hammady_UObT, Jun 15, 2019 :
    no it is not the number but when I try to call any of my contacts or try to call back a missed call it won't dial I keep pressing many many times then it dial
    so I can't dial from my contacts list or even from missed call list
    it is dangerous for me as I am a doctor and emergency is my specialty and I used to work with my phone to call other doctors in duty
    now I try to memorize all numbers so I can call
    it began only after installing the update
  2. elanglois Lollipop Jun 15, 2019
    elanglois, Jun 15, 2019 :
    Works fine for me. Call customer service.
  3. Sarvesh sawant26694 Cupcake Jun 15, 2019
  4. R1529500080287 Cupcake Jun 15, 2019
    R1529500080287, Jun 15, 2019 :
    my front itself not working , face unlock as wel !
  5. anandshrotriya17 Donut Jun 15, 2019
    anandshrotriya17, Jun 15, 2019 :
    After Updating 9.06 in OP6
    1 Battery drains fast.
    2 Incoming call display wakeup after 5 to 6 second when ringing start.
    3 Not including any new features
    4 lagging.
  6. H1555762060349 Eclair Jun 15, 2019
    H1555762060349, Jun 15, 2019 :
    no lag whatsoever for me
  7. i_am_JSK Froyo Jun 15, 2019
    i_am_JSK, Jun 15, 2019 :
    Is anyone facing speed dial issues? The contacts on the speed dial isn't responding at all.
  8. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    JAGADISH BHATTA, Jun 15, 2019 :
    Try cleaning your phone's camera lens
  9. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    Use SILFER file transfer
  10. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    Its normal if you restart your phone at 90 or above battery
  11. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    Its normal some app is running in background which is draining battery and restarting phone will consume 1-2% battery its normal.
  12. ironass KitKat Jun 15, 2019
    ironass, Jun 15, 2019 :
    You can work it out for yourself... the last stable OxygenOS updates, 9.0.14 & 9.0.6, began rolling out on the 3rd June. Now, see...
    OnePlus update schedule explained
    (If the above link does not open, using the OnePlus Community app, switch to your Google Chrome browser)
  13. dm00389731 Eclair Jun 15, 2019
  14. drl431 KitKat Jun 15, 2019
    drl431, Jun 15, 2019 :
    The link is good using a browser as @ironass suggested. The community app doesn't do well with links.
    ironass likes this.
  15. Flamingskull9 Froyo Jun 15, 2019
    Flamingskull9, Jun 15, 2019 :
    Add me to the list of people having issues with the latest update. It's unfortunate that oneplus is going the way of apple. My SoT was consistently around the 5-6 hour mark with 9.0.4. Went to like 4 hours with 9.0.5 and now is a miserable 3 -3:30 hours on 9.0.6. There is either an attempt at forcing people to buy newer phones or sth clearly wrong with the software development team. Would have downgraded but apparently that causes u to lose all ur data.
    Also having to toggle the airplane mode on and off to get network almost daily.
    Some people can be wrong some of the times, but with so many people complaining, there's got to be a fire for there to be smoke.
    And I have read the posts on how to conserve battery and cleared my system cache multiple times. Downloaded the update from the website and installed it again as well as a firefighting technique but nothing seems to work. Android system and play services are the usual culprits draining battery.
  16. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    Snapchat,Instagram,facebook and PUBG all these are battery draining app so 7 hrs 30 mins SOT is good.If possible remove snapchat
  17. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    Read his comment carefully he didn't call you impatient.:)
  18. JAGADISH BHATTA Ice Cream Sandwich Jun 15, 2019
    I am on latest 9.0.6 update and battery life is good also you need to understand battery life depends on your usage and what apps you have installed on your phone.
    There are some battery draining apps like whatsapp,snapchat,facebook,PUBG,Instagram they cause huge impact on battery life.
    Post a screenshot of battery stats that will be huge help shorting out your issue.
  19. Flamingskull9 Froyo Jun 15, 2019
  20. Flamingskull9 Froyo Jun 15, 2019
    The deal is that my pattern of usage, or the apps I use haven't changed in a year or so. If the battery backup significantly decreases post an update, it is noticeable. I understand ur trying to help, but quite frankly there's not too much to dissect. It's just poor optimisation.
    robin143 likes this.
