260
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. subrata1710 Donut Jun 20, 2019
    subrata1710, Jun 20, 2019 :
    The battery drainage has increased substantially after the update. Kindly fix this bug.
  2. Pravi1205 Froyo Jun 20, 2019
  3. drl431 KitKat Jun 20, 2019
    drl431, Jun 20, 2019 :
    Try clearing the cache for the phone app, then restart your device.
    ironass likes this.
  4. Abid_Ansari Eclair Jun 20, 2019
    Abid_Ansari, Jun 20, 2019 :
    I'm facing volume key problem it's not decreasing. after I restart the phone it works Normally
  5. drl431 KitKat Jun 20, 2019
    You might have a misbehaving app. Figure out likely suspects and start uninstalling.
    ironass likes this.
  6. Abid_Ansari Eclair Jun 20, 2019
    how can I find it? I mean which aaps
  7. drl431 KitKat Jun 20, 2019
    Good question. But only you can answer it. Maybe start with recently installed or updated apps.
  8. Abid_Ansari Eclair Jun 20, 2019
  9. Abid_Ansari Eclair Jun 20, 2019
    drl431
    Good question. But only you can answer it. Maybe start with recently installed or updated apps.​
    I have uninstall all the APK which I have downloaded from Google
  10. drl431 KitKat Jun 20, 2019
    If you arbitrarily side load apk's, you put your device at risk for problems.
    ironass likes this.
  11. Abid_Ansari Eclair Jun 20, 2019
    but now I have uninstall all the APKs
  12. drl431 KitKat Jun 20, 2019
    Ok? You posted this twice. Do you mean there is still a problem?
  13. Abid_Ansari Eclair Jun 20, 2019
    this problem happens sometimes not everytime the next it's happens again
    I will post
  14. Roman_Vidales Cupcake Jun 20, 2019
  15. drl431 KitKat Jun 20, 2019
    If your carrier provides it.
    ironass and Kytharsis like this.
  16. imwasimkhan Eclair Jun 21, 2019
  17. Aditya Nahar Gingerbread Jun 21, 2019
    Aditya Nahar, Jun 21, 2019 :
    havnt any of u tested slow motion with oneplus 6 after this update. they have removed all the funtions provided to us. like selecting the area's start and end for slow motion, lenght of video, re-editing etc. it just sucks now
  18. imran1551 Cupcake Jun 21, 2019
    imran1551, Jun 21, 2019 :
    RAM management has become worst after the update. please fix it oneplus, dont do like other companies. forgetting about older models after the launch of new ones.
    L1546689274013 likes this.
  19. H1555762060349 Eclair Jun 21, 2019
  20. manu270892 Cupcake Jun 21, 2019
    manu270892, Jun 21, 2019 :
    Facing the data network connectivity after the update. Takes a lot of time to connect with mobile data and also the connection is not stable.
    Anyone else facing the same issue??
