261
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. imran1551
    Cupcake Jun 29, 2019
    G_abhilash_s_jdHz likes this.
  2. beingankitjain
    beingankitjain , Jun 29, 2019 :
    Battery issue isn't solved yet. I am feeling as if I am using apple. The battery is draining so fast. So fast that I am thinking of returning my phone back.
    G_abhilash_s_jdHz and surendra91 like this.
  3. Kytharsis
    Marshmallow Jun 29, 2019
    Kytharsis , Jun 29, 2019 :
    You can't complain about the battery if you neglect to show any screenshots of your battery.
    drl431 likes this.
  4. beingankitjain
  5. LegolasX
    Jelly Bean Jun 29, 2019
    LegolasX , Jun 29, 2019 :
    so you are deciding this by just using your brand new device for a day?
    RandomUserOne, drl431 and Kytharsis like this.
  6. beingankitjain
    Yes. May be I am wrong. May be the phone will take time to adjust.
    I had used pie in custom roms before (Xiaomi) and had experienced variety battery drains from roms to roms. I'll be putting my device to tests and will share whatever I'll get to help community.
    drl431 likes this.
  7. Nagendra_Kamath
    Nagendra_Kamath , Jun 29, 2019 :
    In 6t some of apps are closing unexpectedly(including google apps). Is any one knows or come across this issues. please help
  8. Y1560786679241
    Y1560786679241 , Jun 29, 2019 :
    this because you use oxygeon os open beta version please install stable version of oneplus
  9. ironass
    Lollipop Jun 29, 2019
    ironass , Jun 29, 2019 :
    Why are you blaming this on the Open Beta test firmware release?
    I am on Open Beta and do not experience this.
    What makes you even think that this user is even on Open Beta test firmware, judging from his post in this stable OxygenOS thread...
    Kytharsis, drl431 and Auristic like this.
  10. Y1560786679241
    because open beta is not properly tasted and dont remove bugs properly...i am also use open beta and now i am downgrade to stable 9.0.6
  11. Nagendra_Kamath
    for your kind information I'm not using beta...
    ironass likes this.
  12. Y1560786679241
    oh than its device internal fault
  13. ironass
    You really do not know what on earth you are talking about do you? :rolleyes:
    ... and as if to prove my point... he is not on Open Beta.
    I would suggest backing up your important data and performing a Factory Reset and a fresh install of apps and settings.
  14. Amarjeet Sahoo
    Gingerbread Jun 30, 2019
    Amarjeet Sahoo , Jun 30, 2019 :
    Hi..
    The screen on time on my 6T as per my observation has gone down with time. I used to get close to 8 to 8.5 hrs of screen on time but the SOT has gone down with time. Now I am getting close to 4 to 4.5 hrs of SOT as of now. I am an average user who does not play much of games and the type of number of apps that I have been using has not changed much over time.
    I don't know what the issue is. Has the battery degraded over a course of 8-9 months or is there an issue with each successive updates.
    What do you think?
  15. Srínívas Sñ
  16. drl431
    Lollipop Jun 30, 2019
    drl431 , Jun 30, 2019 :
    Lots of possible causes...
    First uninstall any junk apps such as memory cleaners/boosters, battery monitors, antivirus, etc.
    Also charge the phone overnight, at least occasionally, to allow system to optimize for battery usage.
    Kytharsis and ironass like this.
  17. maduriravigoud
    Cupcake Jun 30, 2019
  18. drl431
    If all your photos are tagged as favorite, they might only show in the favorite folder.
    Or try looking with the file manager.
    Kytharsis likes this.
  19. drl431
    A service center would do that for you. It is not expensive.
  20. G_Marko_Zornada_Dyws
