263
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. Xnatty
    Honeycomb Jun 3, 2019
    Xnatty , Jun 3, 2019 :
    no don't be judgemental, OnePlus needs to try new patches closed for 2 weeks then on beta then we can have it on stable, right now I'm sure it's being tested on closed beta , here is a statement from David!
    drl431, Maverick2.0 and iBharat like this.
  2. Xnatty
    still on beta, it will probably be included on the next stable update!
    Staticx likes this.
  3. iBharat
    Froyo Jun 3, 2019
    iBharat , Jun 3, 2019 :
    all said n done, it would've been proper if the latest security patch was released 15-20 days after being tested, seeing as OnePlus 6/6T are now getting software updates quarterly/bi-monthly... my last update being in April with March 2019 security patch.!!
    just saying!! ‍♂️
    Xnatty likes this.
  4. G_Karothikeyan
    Ice Cream Sandwich Jun 3, 2019
  5. MachoRambo
    MachoRambo , Jun 3, 2019 :
    Got the update. Thank you OP team. Now that launches are over please try to give monthly security patch updates.
  6. Rezaur08
    Cupcake Jun 3, 2019
  7. Dev Chopra
    Eclair Jun 3, 2019
    Dev Chopra , Jun 3, 2019 :
    Please add an audio tuner profile for the OnePlus Bullets wireless 2 on the Oneplus 6/6T.
    zervinb likes this.
  8. manasarora98
    manasarora98 , Jun 3, 2019 :
    What's the launcher part of the update?
    Do we have a pin option for hidden space as well?
    I could not find it anywhere.
    Plus not included in the OnePlus 6 changelog.
    Also network speed mini icon still not received cant see speed still with VoLTE sign on.
    Massive Feature updates hoped in next stable release.
    Could not replicate the buggy issue of notification bar icons yet as reported by others...hopefully this should be fixed ASAP if present as that strips us of major features of a phone: (notifications and time and networks available display)
  9. S1559411353565
    Cupcake Jun 3, 2019
  10. Marius95
    Cupcake Jun 3, 2019
    Marius95 , Jun 3, 2019 :
    We need also an update for camera for user who have oneplus 6, because front camera and portrait mode don't work properly.
    JAGADISH BHATTA likes this.
  11. Xnatty
    if you really want the network speed to be displayed like mine here ( just to show you)....
    disable battery percentage and alarm icon if it's ON.
    the reason you can't see the network speed is because it doesn't have enough space to be displayed!
    drl431 and Maverick2.0 like this.
  12. saivychawla
    Froyo Jun 3, 2019
    boff_hell_Joe and Xnatty like this.
  13. manasarora98
    Well probably you are unaware that oneplus in its last to last beta update rolled out the new Speed display so that it takes less space...and offcourse my Alarm sign is off for status bar, auto rotate sign is off too and battery percentage is off but circular battery is On(that is required to me kind of, and VOLTE is On that is important to me as I have both sims on Volte and need to be on the one in any area that supports VoLTE.
    Xnatty likes this.
  14. M1559583477222
    Eclair Jun 3, 2019
  15. Xnatty
    I understand, just a quick solution if you needed. : - )
    Staticx and manasarora98 like this.
  16. Navjit_Iron.10
    Cupcake Jun 3, 2019
  17. atinjadia
    Donut Jun 3, 2019
  18. manasarora98
    Xnatty likes this.
  19. manasarora98
    I could not replicate the same issue on my OnePlus 6 following the same steps as u suggested
  20. M1559583477222
    Eclair Jun 3, 2019
