261
OxygenOS 9.0.14 OTA for the OnePlus 6T and OxygenOS 9.0.6 OTA for the OnePlus 6
  1. H1555762060349 Eclair Jun 8, 2019
    H1555762060349, Jun 8, 2019 :
    what I have noticed is that volume of speaker is reduced on pie as compared to Oreo is it true?
  2. dm00389731 Eclair Jun 8, 2019
    dm00389731, Jun 8, 2019 :
    yeah +1
    i aslo faced these issues
    f00tbaLL likes this.
  3. gangahit Cupcake Jun 8, 2019
    gangahit, Jun 8, 2019 :
    reset network settings and remove the sim, connect on different phone , then connect it back to one plus
    it worked for me, try and let me know
    f00tbaLL and dm00389731 like this.
  4. dm00389731 Eclair Jun 8, 2019
    ironass
    Latest updates are now available in the official OnePlus Download Store
    i downloaded the 9.0.14 version from updater app which is about 400 mb but in this site the version size shows 9.0.14 is there any difference and if then clean me if i flashed this update of 1.65 gb then my data will be erased?
    A1550387522048 likes this.
  5. Z1560019039191 Cupcake Jun 8, 2019
  6. ironass KitKat Jun 8, 2019
    ironass, Jun 8, 2019 :
    The official OnePlus Download Store always offers the FULL .zip update in case users are rooted, have custom recoveries or have modded their phones. The smaller incremental updates are for unadulterated phones.
    srikanth.s likes this.
  7. G_mahen_sam_Zdas Gingerbread Jun 8, 2019
    G_mahen_sam_Zdas, Jun 8, 2019 :
    Improved confirm password UI for hidden space
    how to enable this feature? and also have not received this update on OP6
    ilesh chainani and Dormix like this.
  8. Kytharsis Marshmallow Jun 8, 2019
    Kytharsis, Jun 8, 2019 :
    Are you sure you have a 6T?
  9. F1540997428699 Cupcake Jun 8, 2019
  10. F1540997428699 Cupcake Jun 8, 2019
  11. A1550387522048 Gingerbread Jun 8, 2019
    A1550387522048, Jun 8, 2019 :
    Good question.
  12. H1555762060349 Eclair Jun 8, 2019
  13. H1555762060349 Eclair Jun 8, 2019
  14. prajwalsavadi Cupcake Jun 8, 2019
    prajwalsavadi, Jun 8, 2019 :
    why there r updates like Zen mode and screen recorder are available for only some users and not for others
  15. P1560025715850 Cupcake Jun 8, 2019
    P1560025715850, Jun 8, 2019 :
    hi to all! i just want to ask if there is somebody experiencing the Wifi connection problem during a phone call? from the last month update and also the new update i am experiencing a problem with the wifi connection Everytime i am on a phone call. it is like the wifi connection of my phone is weaker. when i try to search something on YouTube it doesn't load the video . i understand if it is data connection but it wasn't. phone call should not affect wifi but i have problem with that. can anyone suggest if i need to do something i am using op6t. thanks
  16. drl431 KitKat Jun 8, 2019
    drl431, Jun 8, 2019 :
    Your screen was on the entire time since charging!! That looks like you would get over 7 hours of screen on time. I usually get about 7 hours of screen on time also, but I don't have the screen on all the time. So I get 3 or 4 days between charges with that same 7 hours of screen on time.
  17. drl431 KitKat Jun 8, 2019
    Look around the forum. You will see, in the beta thread, that those 2 features are being tested in the open beta release. So they should be in an upcoming stable release, which are about every 2 months. OnePlus does not release ETA's.
    prajwalsavadi likes this.
  18. L1560027750888 Cupcake Jun 8, 2019
    L1560027750888, Jun 8, 2019 :
    the update is not downloading even though the update is available... how do I get it to download, I have tried restarting the phone but still the update is not downloading
  19. G_Abhinav_Nayyar_BUEr Cupcake Jun 8, 2019
    G_Abhinav_Nayyar_BUEr, Jun 8, 2019 :
    After the new update the slider button is not functioning properly... Even slide to the loud the mut notification is not getting off
  20. L1554265747145 Eclair Jun 8, 2019
    L1554265747145, Jun 8, 2019 :
    You don't have a 6t most likely
