304
OxygenOS 9.0.15 OTA for the OnePlus 6T and OxygenOS 9.0.7 OTA for the OnePlus 6
  1. GrooVek Cupcake Jul 11, 2019
    GrooVek, Jul 11, 2019 :
    Yup, I have te same problem
  2. Kytharsis Marshmallow Jul 11, 2019
    Kytharsis, Jul 11, 2019 :
    Did either of you calibrate the battery?
    ironass likes this.
  3. Sanjida Shahabuddin Cupcake Jul 11, 2019
  4. Kytharsis Marshmallow Jul 11, 2019
    Read my post above.
    ironass likes this.
  5. Sanjida Shahabuddin Cupcake Jul 11, 2019
  6. GrooVek Cupcake Jul 11, 2019
    I'm after 3 charing cycles, more than 3 and I feel, battery percentage decrease quicker than before
  7. Sanjida Shahabuddin Cupcake Jul 11, 2019
    Sanjida Shahabuddin, Jul 11, 2019 :
    did u calibrate it?
  8. GrooVek Cupcake Jul 11, 2019
    I think yes, but it's not the same. Maybe more charge cycles and will be okay, or factory reset.
  9. L1543929763295 Donut Jul 11, 2019
    L1543929763295, Jul 11, 2019 :
    Anyone else have issues with trusted places?
    At home i could unlock my phone with just a swipe, now it's like this feature is disabled .
    Also it started to heat up quite badly when i use google maps for example.
    And i can't get 5 hours of screen time with a full charge (but this might be a feature actually).
    Naveen_006 likes this.
  10. L1562897345480 Cupcake Jul 12, 2019
  11. Kytharsis Marshmallow Jul 12, 2019
  12. L1562897345480 Cupcake Jul 12, 2019
  13. Kytharsis Marshmallow Jul 12, 2019
    Kytharsis, Jul 12, 2019 :
    Run over to a restaurant and connect to their WiFi if you can. Otherwise, just dismiss it.
  14. L1562897345480 Cupcake Jul 12, 2019
    L1562897345480, Jul 12, 2019 :
    cannot dismiss[e]1f602[/e].. maybe need to find a place, thanks.
    Kytharsis likes this.
  15. K1562224153158 Cupcake Jul 12, 2019
  16. laurenzo87 Gingerbread Jul 12, 2019
  17. I1561164494238 Cupcake Jul 12, 2019
    I1561164494238, Jul 12, 2019 :
    hey any one reply me i have buying last month one plus 6t..
    I have not satisfied in battery...
    I think my battery Drain fast...
    any solution is there kindly let me
  18. K1562224153158 Cupcake Jul 12, 2019
    K1562224153158, Jul 12, 2019 :
    your battery is too good bro tell that to op6 users our battery is drain tooo fast you have 3700 may and we have 3300 mah
    I1561164494238 likes this.
  19. I1561164494238 Cupcake Jul 12, 2019
    ok bro but I am not satisfied??????????
  20. mussaibraheem10@ Donut Jul 12, 2019
    mussaibraheem10@, Jul 12, 2019 :
    After update Em Facing Call Drop issue in My 0P 6...☹️
    After Few Seconds Automatically Calls Droping...[e]1f622[/e]
    Speaker Sounds Not Clear.
    Wifi Not Stable Performing.
    Lots Of Bugs in This update...[e]1f620[/e]
    ppavan1 likes this.
