327
OxygenOS 9.0.15 OTA for the OnePlus 6T and OxygenOS 9.0.7 OTA for the OnePlus 6
  1. Rvijaygupta
    Cupcake Jul 20, 2019
    Rvijaygupta , Jul 20, 2019 :
    tried that didn't worked for me
  2. DeluxeNoone
    Ice Cream Sandwich Jul 20, 2019
  3. Karan_bh
    Cupcake Jul 21, 2019
    Karan_bh , Jul 21, 2019 :
    JUST TRIMMED 21 seconds from OnePlus Gallery Editor AND SEE IT INCREASED THE SIZE FROM 23MB TO 182MB. WTH OnePlus
    I have complained about it before but got no reply!
  4. rohitsharma_j22
    Gingerbread Jul 21, 2019
    rohitsharma_j22 , Jul 21, 2019 :
    Anybody noticed, Media volume has no effct of increasing or decreasing after around 60%. After 60% its showing volume increase and decrease on bar, bt no effect felt on speaker. 60% is maximum.
    Is this actuallyy a problem or m i using some weird setting in phone. Mine is OP6.
  5. rohitsharma_j22
    My battery drain has been increased just after updating to this current update. before this update i have never faced such problem after any update.
    Previously i was getting around 6-6.5 hrs SOT, but now with same usage m getting around 4-4.5 hrs only. i have done cache clearing (however its of no use now), tried full night charging few times.
    binu678 likes this.
  6. drl431
    KitKat Jul 21, 2019
    drl431 , Jul 21, 2019 :
    Look for and uninstall any 3rd party junk apps such as memory boosters/cleaners, antivirus, battery monitors, etc. Also, most social media apps frequently sync with their servers. You might be able to reduce the sync interval.
    Kytharsis likes this.
  7. rohitsharma_j22
    i hv no such 3rd party or junk app, battery stats are all normal for all apps. using greenify, which use to hibernate all social media apps after use. it all was nice just before the currnt update. after update dont know what happen. now i. th8nking about a factory reset, however this is the most disgusting and irritating solution.
  8. Kytharsis
    Marshmallow Jul 21, 2019
    Kytharsis , Jul 21, 2019 :
    What did you do to get to the SOT on the previous update?
  9. dm00389731
    Eclair Jul 21, 2019
  10. P1561454958179
  11. Kytharsis
    If you haven't gotten it yet, you're either on beta or one of the last to get it.
  12. B1542825906754
  13. B1542825906754
  14. binu678
    Froyo Jul 21, 2019
    binu678 , Jul 21, 2019 :
    same problem for me also
  15. binu678
    Froyo Jul 21, 2019
  16. binu678
    Froyo Jul 21, 2019
    same problem for me aslo
  17. N1563654616241
    N1563654616241 , Jul 21, 2019 :
    u can find it in quick setting
    go in edit nd u can find it there
  18. rohitsharma_j22
    nothing special. just normal mobile usage. no special settings.
    Today after posting here, i tried one thing, i switched off adaptive battery, and till now finding it beneficial. After 50% battery its around 3hr 15 min SOT.
    Guys, all who are facing battery drain issue please try once, Switch off the Adaptive Battery and then check. It may solve your problem.
    N1563654616241 likes this.
  19. jigarpatel0034
  20. E1563722793417
    E1563722793417 , Jul 21, 2019 :
    In my OP 6T, I'm facing issue in uploading images in WhatsApp. The quality is so poor that I had to delete the picture Everytime I upload on status of share with people.
    It doesn't accept the high resolution pictures taken from phone camera and the image quality degrades.
    Earlier it wasn't like this, I have no clue what went wrong all of sudden.
    Can anyone please help me with the solution to this?
    Thanks in Advance!
