389
OxygenOS 9.0.16 OTA for the OnePlus 6T and OxygenOS 9.0.8 OTA for the OnePlus 6
  1. MAHEDI HASSAN (F.M)
    Honeycomb Aug 10, 2019
    MAHEDI HASSAN (F.M) , Aug 10, 2019 :
    yo see my video there when dc dimming active screen brightness low but ambient display show high brightness...
  2. unnikrishnan_s
    Gingerbread Aug 10, 2019
  3. S1541861021938
    Cupcake Aug 10, 2019
  4. SuhailNahaz
    Eclair Aug 10, 2019
  5. MAHEDI HASSAN (F.M)
    just download down grade rom..
  6. Sun90
    Starting Point Expert Community Expert Aug 10, 2019
    Sun90 , Aug 10, 2019 :
    You need to wait till the full zip file of the stable 9.0.8 is made available for download on OnePlus website download section.
    Once available, you can download and flash it the same way you did with openbeta.
    ironass likes this.
  7. unnikrishnan_s
    unnikrishnan_s , Aug 10, 2019 :
    are u sure about it ?
  8. Sun90
    Sure about what?
  9. unnikrishnan_s
    can i download this zip file ?
  10. unnikrishnan_s
    Sun90
    Sure about what?​
    i mean, is this roll back possible
    because can i roll back to oreo and then, upgrade to pie
  11. AmitShruti4112702
    Donut Aug 10, 2019
  12. Arun_Krr
    Arun_Krr , Aug 10, 2019 :
    Any improvement for screen brightness... Whether the brightness slider sensitivity improved??....
    In OnePlus 6?
  13. Sun90
    Why do you need to roll back to oreo?
    What's the issue with the current open beta you are using?
    ironass likes this.
  14. unnikrishnan_s
    battery draining issue on beta. so, i roll back to stable
  15. Sun90
    And you expect stable to give you better battery life?
    You should be aware that downgrade needs data wipe, so instead , do it on current open beta build and see.
    Also you need to check what's draining the battery and take action accordingly.
  16. hharan618
    Eclair Aug 10, 2019
    JamesBlode007 likes this.
  17. hero2605
    hero2605 , Aug 10, 2019 :
    last time i update my phone with oxygen updater app, will that cause any issue with the normal update that i get thru setting, because with that method the change log is not visible
  18. MAHEDI HASSAN (F.M)
  19. MAHEDI HASSAN (F.M)
  20. Ch Venkatesh
    Eclair Aug 10, 2019
