390
OxygenOS 9.0.16 OTA for the OnePlus 6T and OxygenOS 9.0.8 OTA for the OnePlus 6
  1. kolasubbu
    Cupcake Aug 11, 2019
    kolasubbu , Aug 11, 2019 :
    When shall I expect update? Has official roll out update started? Why, I have not received so far?
  2. RicRod
    Eclair Aug 11, 2019
    RicRod , Aug 11, 2019 :
    I do Not want Zen Mode in the next software or I'm taking leagal action please remove zen mode that was added to the one plus 6T devices the latest software OxygenOs version 9.0.16 I didn't ask for that and it a data hogg.
    Wirelessss likes this.
  3. ChicooBerry
    ChicooBerry , Aug 11, 2019 :
    my friend got this update ...few days ago and I didn't get this update ! what's the reason ? :(
    kolasubbu likes this.
  4. kolasubbu
    simply wipe the chached data at once though rebooting that's it.
  5. kolasubbu
    are you using VPN?
  6. anwarlucas
    Eclair Aug 11, 2019
    anwarlucas , Aug 11, 2019 :
    it was through official download, I will try clearing the phones cache through recovery mode and see if that helps, I'll post an update if I don't see the problem persisting
  7. ChicooBerry
  8. kolasubbu
    shall I get update or not? Is there any specific time for customers to receive that update. Then why I did not arrive on my phone still?
  9. kolasubbu
  10. RicRod
    Eclair Aug 11, 2019
  11. ChicooBerry
  12. kolasubbu
  13. kolasubbu
  14. Abhinandan parhi
    Abhinandan parhi , Aug 11, 2019 :
    the issue is my setting part..when i search anything on setting search bar that time automatically my setting bar crashed .i don't know why it happen again and again ...i need the solution ????
  15. seansandhu
    Froyo Aug 11, 2019
    seansandhu , Aug 11, 2019 :
    @Manu have you guys fixed ram management issue on 6T?
    I am sure you guys are aware that 6T kills the background app if you leave it for more than 30 seconds. like playing PubG for example.
    And yeah, deep optimisation and all other settings are turned off.
    Can you guys fix this? this issue isn't there on OP6 or for that matter on my old 5T.
  16. kolasubbu
    I would like to know and join if any WhatsApp group is there for OnePlus phone users?
  17. Sahildayal24
    Eclair Aug 11, 2019
    Sahildayal24 , Aug 11, 2019 :
    Still pubg cannot be played at HDR with extreme frame rate.... when will OnePlus 6/6T be able to run pubg at HDR with extreme frame rate.
    Jaberjb and Duggu143 like this.
  18. JP Llaga
    Froyo Aug 11, 2019
    JP Llaga , Aug 11, 2019 :
    Pls add an external mic feature in the next update..
    then fix the front camera blur feature... when taking a pic far in the camera..
    Thank you..
  19. JP Llaga
    Froyo Aug 11, 2019
    Hey its possible.. Use BAGT APP in the Google Play Store.. for 60fps HDR setting..
    Sahildayal24 and kolasubbu like this.
  20. Sahildayal24
    Eclair Aug 11, 2019
    thanks
