340
OxygenOS 9.0.17 OTA for the OnePlus 6 and OxygenOS 9.0.9 OTA for the OnePlus 6T
  1. KillerBipin
    Cupcake Sep 28, 2019
  2. KillerBipin
    KillerBipin , Sep 28, 2019 :
    nope
  3. Ahmed_98
  4. KillerBipin
  5. Kytharsis
    Marshmallow Sep 28, 2019
    Kytharsis , Sep 28, 2019 :
    Actually, they're deleting posts that're unrelated to the actual current build and/or complaining about not getting Android 10.
    drl431 likes this.
  6. W1535868078507
    Eclair Sep 28, 2019
  7. Kytharsis
    Use Oxygen Updater if you're that impatient.
  8. W1535868078507
    Eclair Sep 28, 2019
    W1535868078507 , Sep 28, 2019 :
    wat about default system update
  9. Kytharsis
    Same exact update.
  10. W1535868078507
    Eclair Sep 28, 2019
  11. ShabanPlayz
    ShabanPlayz , Sep 28, 2019 :
    Spam tapping on the screen while volume panel is shown causes funky visual effects, the volume panel starts dancing. please fix
  12. Kytharsis
    No, what I mean is, using Oxygen Updater will give you the exact same update as the update you'll get OTA but on your own time.
  13. Yash chawla
    Eclair Sep 28, 2019
    Yash chawla , via OnePlus 6 , Sep 28, 2019 :
    have you tried to clear Google services framework cache? disable google assistant if you don't need it.
    try installing the beta version of the latest Google APK, see if there is any app which has voice recorded or facilities similar to Google assistant.
    L1531543331227 likes this.
  14. ramkr1607
    Froyo Sep 28, 2019
  15. ramkr1607
    Froyo Sep 28, 2019
    ramkr1607 , via OnePlus 6 , Sep 28, 2019 :
    but it's good to wait for auto update. bcuz after updating through oxygen updator the log is not shown.
  16. Messagepads
    Gingerbread Sep 28, 2019
  17. I1562426813401
    Donut Sep 28, 2019
    I1562426813401 , Sep 28, 2019 :
  18. Kytharsis
    Does the log really matter?
  19. G_Sơn_Nguyễn_Giang_xzOT
    G_Sơn_Nguyễn_Giang_xzOT , Sep 28, 2019 :
    I recently bought an used Oneplus 6 model A6000. My device is currently running Oxygen OS 9.0.8 (it supposedly shipped with Hydrogen OS) and I haven't received any update yet (pic)
    My question is: Will I be able to automatically receive OTA updates in the future or do I have to install it manually? I am unaware of how the previous owner installed Oxygen OS on this phone, so I don't know whether his methods affect my ability to receive OTA updates.
  20. kaihp
    Jelly Bean Sep 28, 2019
    kaihp , Sep 28, 2019 :
    Yes, you should receive the OTA updates automatically. Note that the updates are rolled out incrementally, so it can take some time to get them. If you can't wait, use the Oneplus Updater app from Google Play store or do a manual download of the ROM to the root folder and use "Local install".
    I've posted a link to the full 9.0.9 ROM here: https://forums.oneplus.com/threads/...-and-ota-updates.835607/page-17#post-20795054 thread.
