791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. O_DARSHAN_N_009
    Gingerbread May 25, 2019
    O_DARSHAN_N_009 , May 25, 2019 :
    ya it is working awesome till now 32hrs since i updated it
  2. J1537651042649
    Cupcake May 25, 2019
  3. G_Gabriele_Bocci_ltGH
    G_Gabriele_Bocci_ltGH , May 25, 2019 :
    Hello!
    Performances and lags absolutely better than the previous version, maybe a little bit more .ms to unlock the phone but it's like this since the first CB1.
    Increasing lag in CB1&2 with Gmap, now a little better but I don't know if it's the application that causes phone to lag, well in CB2 sometimes doesn't even shows the maps, only the voice was guiding me
    Hope I can Help!
  4. I1543025385072
  5. O_DARSHAN_N_009
    oxygen Updater is a way to update .... local upgrade..
    Kevin Thomas Tom likes this.
  6. J1537651042649
    J1537651042649 , May 25, 2019 :
    i tried with the local updater but it is showing
  7. O_DARSHAN_N_009
  8. G_Gabriele_Bocci_ltGH
  9. J1537651042649
    can you send me the link to download the latest version
  10. O_DARSHAN_N_009
  11. AnuGeorge
    AnuGeorge , May 25, 2019 :
    I love this stable pie with new features and after full charge only 4hrs SOT it's fair but will see does it get better.
    iceburners likes this.
  12. J1537651042649
    deleted .. but i need link for the latest version
  13. Narender
    Eclair May 25, 2019
  14. G_Gabriele_Bocci_ltGH
    well, download Oxygen Updater App, choose the community build versions, and download the latest of it, then proceed with a local update.
    O_DARSHAN_N_009 likes this.
  15. pgsk97
    Honeycomb May 25, 2019
    pgsk97 , May 25, 2019 :
    try oxygen updater
  16. pgsk97
    heyy can u tell me properly how to fix this??
  17. Kiran.a.joseph
    Jelly Bean May 25, 2019
    Kiran.a.joseph , May 25, 2019 :
    After the upgrade, parallel whatsapp had issues when I send message from it. I cleared the data and cache for parallel whatsapp and registered the same mobile number with parallel whatsapp and then it worked fine
  18. G_Mateusz_Gąbka_hHQj
  19. venkatasiva08
    venkatasiva08 , May 25, 2019 :
    pgsk97
    heyy can u tell me properly how to fix this??​
    1) do a full install from oxygen updater
    2) install one instance of WhatsApp and full set it up. rename the app in app drawer to some other name
    3) now go to boot menu by holding volume low button and power button. clear cache only
    4) now go to advanced menu after restarting and enable parallel app.
    5) try to setup this parallel app.
    6) if it doesn't work, go to storage and clear data & clear cache for parallel app.
    7) now restart again and setup the parallel app. should work
  20. pgsk97
    ok will try
