791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. OPO OOS lover
    Jelly Bean May 25, 2019
    OPO OOS lover , May 25, 2019 :
    The same was said on Oreo Stable updates that there will be no new feature after Face unlock update OxygenOS 5.0.3 yet on OxygenOS 5.0.7 came a new feature that supports USB Type-C with call receive function support and then hotfix update
    But who knows.
  2. G_Gabriele_Bocci_ltGH
    Gingerbread May 25, 2019
    G_Gabriele_Bocci_ltGH , May 25, 2019 :
    well, have you choose the right update.zip file from local update?(if you have more than one), have you tried to do the update from the recovery mode?
  3. Narender
    Eclair May 25, 2019
  4. pgsk97
    Honeycomb May 25, 2019
  5. G_Mateusz_Gąbka_hHQj
    Cupcake May 25, 2019
    G_Mateusz_Gąbka_hHQj , May 25, 2019 :
    I tried file from oxygen updater and downloand link on this thread - same problem. Yes i tried install this file from recovery mode but when i do this its go back to choose file step without any error or information...
  6. andQlimax
  7. Piyucq10
  8. G_Gabriele_Bocci_ltGH
    the OTA are you currently running into your device?
    CB2?
  9. G_Mateusz_Gąbka_hHQj
    nNo it's 5.0.8 Oreo. OP3. with unlock bootloader but i never had this problem before...
  10. Endri_Matodashaj
    Endri_Matodashaj , May 25, 2019 :
    any body has unlocked bootloader and is in community beta
    P1555919653374
    p
    as it shows this warning at the bottom​
    Muhitpias
    yes, it is safe​
    Hello!
    I would like to say that this 9.0.2 works better than the previous Community build 2.
    No more phone calls problem (loss of quality and black screen during calls), seems working better even the fingerprint sensor and the batter as well.
    Sadly I don't use parallel apps so I can't evaluate it.
    Have a nice weekend!​
    i'm on comm.beta 2.. i see that at the warning is shown if the bootloader is unlocked i have to lose all thr data . is possible to update through oxygen updater without loosing any?
  11. G_Gabriele_Bocci_ltGH
    The Community Builds only works if you have your bootloader set by default (locked) so you have to look it first, then try again
    G_Mateusz_Gąbka_hHQj likes this.
  12. wospino
    Ice Cream Sandwich May 25, 2019
    G_Gabriele_Bocci_ltGH likes this.
  13. G_Leung_L.C._zTpk
  14. Fursan Afzal
  15. G_veeresh_hiremath_GKNu
  16. G_Gabriele_Bocci_ltGH
    however Oxygen Updater app is only to download the update, the app shows you the "how to update it".
    you have to do it manually (by local or recovery mode)
    Endri_Matodashaj likes this.
  17. Endri_Matodashaj
    thanks.. yeah i understand. my worries are that i have un unlocked bootloader, and having to update through local storage I may loose all the datas
  18. AnuGeorge
    AnuGeorge , May 25, 2019 :
    I wish 1+ would have power bank with dash charge or warp charge so easy to charge on the go. Hope in future 1+ deliver a dashing power bank.
  19. G_Gabriele_Bocci_ltGH
    In any case a backup is suggested. Even for the locked bootloader ones. may the luck be with you :)
  20. Endri_Matodashaj
    grazie 1000, ci provo.. tanto da 3 settimane ho fatto comm.beta 1 comm.beta 2 e adesso questo.. mi è diventata una routine [e]1f61c[/e]
    grazie, ciao [e]1f609[/e]
