791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. ChengxiangTan
    Donut May 25, 2019
  2. G_Gabriele_Bocci_ltGH
    Gingerbread May 25, 2019
    G_Gabriele_Bocci_ltGH , May 25, 2019 :
    figurati, allora avrai sicuramente fatto dei salvataggi :)
    comunque questa release è nettamente migliore rispetto alle altre due, almeno per quanto ho potuto testare in questi due giorni ! ciaociao
    Endri_Matodashaj likes this.
  3. SimonRam
    Lollipop May 25, 2019
    SimonRam , May 25, 2019 :
    Just charge as regular. 80-20 is fine.
    It'll settle down after a few days believe me.
  4. Gokul_Balakrishnan
    Cupcake May 25, 2019
  5. pvsuru
    Eclair May 25, 2019
  6. G_Erasmo_Vega_Fonseca_zW
    G_Erasmo_Vega_Fonseca_zW , May 25, 2019 :
    This Is Global version
  7. satyaraomm
    Donut May 25, 2019
    Ibrahim Attar likes this.
  8. shyind
    Eclair May 25, 2019
  9. TheMystic
    TheMystic , May 25, 2019 :
    There are two theories doing the rounds.
    One says it is advisable to do so. I have always followed it and never faced any issues.
    Another theory says you must not wipe it because you will be making the phone redo all the cache building work, which will result in extra battery consumption and may be other problems too like lags, overheating, etc.
    In short, I would start afresh with every major Android upgrade, like in this case from Oreo to Pie. So, take a backup of all your files and app data and do a clean install (or factory reset).
  10. TheMystic
    Apk is an app, not OS.
    The only way you can install an OS is either by using the built in updater (or using Oxygen updater if it is that urgent) or by manually flashing the OS. You don't get an OS as an app on Play Store or elsewhere.
  11. OPO OOS lover
    Jelly Bean May 25, 2019
    OPO OOS lover , May 25, 2019 :
    So doesn't this mean that OnePlus should release quick reply in Landscape mode for the OnePlus 3/3T since they had released it for the OnePlus 5?
  12. Kx1707
    Kx1707 , May 25, 2019 :
    Hi mate,
    What's your phone usage like? do you use it for gaming and heavy apps or just regular usage (video streaming, phone call, messaging, etc.?
    Cheers.
  13. CJ_will_NeverSettle_6T
    Froyo May 25, 2019
    CJ_will_NeverSettle_6T , May 25, 2019 :
    I chose the Nexus 6P as my new phone over the OnePlus 3 back in 2016. I really regret that decision :( and now the 3/3T get Pie :eek:
    Next month I'm getting a OnePlus 7. Finally righting my wrong :D
  14. AnuGeorge
    AnuGeorge , May 25, 2019 :
    No gaming not using any heavy apps just regular use.
    Kx1707 likes this.
  15. ZoroKoBoro
    Honeycomb May 25, 2019
  16. Cosmos_NT
    KitKat May 25, 2019
    Cosmos_NT , May 25, 2019 :
    Nah, I'm good replying from notification rather than using my screen portion while watching or playing.
    OPO OOS lover likes this.
  17. fouadmordi
    fouadmordi , May 25, 2019 :
    get the 7 pro.
  18. buzaaiid
    buzaaiid , May 25, 2019 :
    my op3t was on Open beta 30, i tried to flash Android 9 Pie OxygenOS 9.0.2 firmware with twrpbur it gave me error 7, what shal i do?
    Thanks in Advance
  19. Kx1707
    Thanks for sharing, mate.
    Sounds pretty decent might get even better once it settles.
    AnuGeorge likes this.
  20. fouadmordi
