791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Narender
    Eclair May 25, 2019
  2. pgsk97
    Honeycomb May 25, 2019
    pgsk97 , May 25, 2019 :
    no nothing will happen
  3. G_valentin_kritinar_pEhg
    Cupcake May 25, 2019
  4. PriyeshPatil
    Gingerbread May 25, 2019
  5. T1558466917475
  6. _Omar_Embarki_
    _Omar_Embarki_ , May 25, 2019 :
    my oneplus 3t is unlocked bootloader . can i get the official update normally (I mean in update section
    pls reply)
  7. Bierten77
    Froyo May 25, 2019
    Bierten77 , May 25, 2019 :
    Give it a day (or two). It will "stabilize".
  8. G_Willian_Macedo_PEqh
    Eclair May 25, 2019
    Geofrey Kazaula likes this.
  9. Lord_Babass
    Ice Cream Sandwich May 25, 2019
    Lord_Babass , May 25, 2019 :
    Even if I already had tried to wait, maybe it was not long enough.
    Re-tried to update (it was stuck trying) and plugged on charger. After quite a long time I gave it a look and my only app available was updated. Might be solved! To be verified next time an app has an update...
    It’s a relieve ;-)
  10. Kx1707
    Kx1707 , May 25, 2019 :
    Cool!
  11. Deactivated User
    May 25, 2019
  12. sammerasker
    sammerasker , May 25, 2019 :
    You have the right version, that's strange , are you sure lens is not visible...maybe you disabled arcore , check settings>apps , and see if arcore is there and of it's enabled
    Attached a screen showing lens is there on version 3.0.30 on this official release (it's on the broom left )
  13. sammerasker
    It must be something related to how you updated, because here with clean flash , it's there ( or maybe it's 3T related , I have 3)
  14. tpati
    tpati , May 25, 2019 :
    I update by a a local update, don't know how to make that appear again.
    Don't know what's mean doesn't have that too
  15. sammerasker
    Yes loading fine
    Deactivated User likes this.
  16. antonioxiras
    antonioxiras , May 25, 2019 :
    I do this from the beginning but still get installations failed...
  17. gazz1701
    Jelly Bean May 25, 2019
    gazz1701 , May 25, 2019 :
    OnePlus rarely disclose that information - does it really matter that much...
  18. gazz1701
    So you're running the last open beta of Oreo for 3/3T...? Pretty sure read that it's not a straight upgrade for that version... the open beta ended and advise was to install back to stable 5.0.x version.
    Dig up the thread about Pie community beta 2 - read it, think you can download Pie beta from there that will upgrade your July Oreo build... this will upgrade to Pie community beta 2 so 9.0.1. Then you should upgrade okay to the stable Pie 9.0.2.
  19. parvinderkalsi
    Froyo May 25, 2019
  20. TR.Engin.Akbulut
    Donut May 26, 2019
    TR.Engin.Akbulut , May 26, 2019 :
    3t op was very hot but I use and why Turkey does not have a problem in parallel applications OnePlus will also receive sales open 7 pro 12/256 5 Total
