791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Ysfzone
    Froyo May 26, 2019
    Ysfzone , May 26, 2019 :
    me too, i don't show the authenfication ..
    i have OP3 and i update with local method..
  2. vijayanaveen
    Gingerbread May 26, 2019
    vijayanaveen , May 26, 2019 :
    I have got OTA update then how can I do clean flash? If you have link for 3t please mention. I will try for clean flash.
  3. iharshjjain
    Ice Cream Sandwich May 26, 2019
  4. Brijeshah
    Donut May 26, 2019
    Brijeshah , May 26, 2019 :
    ThanQ after a long time we received the update
    there is issue in parallel application 2nd account of WhatsApp is not working showing error unable to connect.
    please give me the solution.
  5. Rahul_2911
    Cupcake May 26, 2019
  6. rajeevdb
    Froyo May 26, 2019
  7. G_Rohan_Kumar_SQjg
    Froyo May 26, 2019
    G_Rohan_Kumar_SQjg , May 26, 2019 :
    it's quite possible that an app is causing such issues.
    I faced the same to the extent that my phone would freeze and restart (without actually) and I would have to enter PIN to unlock.
    The performance was also choppy.
    I uninstalled few apps and now performance is smooth.
    I think VPN app was the culprit because I haven't had those issues after uninstalling it.
  8. Siva_Praneeth_PS
    Froyo May 26, 2019
    Siva_Praneeth_PS , May 26, 2019 :
    Hello Guys,
    After update to Android Pie 9.0.2 My Review for last 48 hrs.
    NOTE: After Update I Hard Reset (Wipe Everything) the mobile.
    - After update, OS running very Smooth, no lagging problem occurred.
    - Caller UI improvement is good, now we can see 40% Caller image on screen.
    - Gaming Mode is Good..
    - Camera clarity & focusing is good compared to previous OS, but Google Lens icon is not showing in my camera, I don't know why?
    - OnePlus Launcher UI improvement is good, easy smooth & customization.
    - Apps Notifications appears is Very nice!!
    - Auto Brightness is ok ok, but need to improve.
    ONEPLUS SOLVE THESE IMMEDIATELY FOR NEXT UPDATE:
    - Parallel Apps Failed, WhatsApp is not working, while registering it's gets error.
    - Coming to Battery -> Compare to previous OS, Battery is not good, draining very fast.
    - Google Lens Icon is not showing in my camera.
    - While Restarting/Power On, the booting process is very slow, it takes time to startup.
    - Night Mode is not working properly, I set to custom time, but not ON automatically, we need to ON manually.
  9. ShinojR
    Froyo May 26, 2019
    ShinojR , May 26, 2019 :
    Nope. Oxygen updater will not work
  10. ssaikiran92
    Honeycomb May 26, 2019
    ssaikiran92 , May 26, 2019 :
    the mobile network battery drain is still present from CB1 to Stable update. After giving continuous feedback and required logs to the Dev team, this issue was not resolved. Guess battery drain is not their concern anymore on OP3.
    I still face heck of a Mobile network drain on stable 9.0.2.
    mikica023 likes this.
  11. ShinojR
    Froyo May 26, 2019
  12. G_shailu_patidar_XECm
  13. iharshjjain
  14. Abrar@qureshi
    Eclair May 26, 2019
    Abrar@qureshi , May 26, 2019 :
    If I'll update my phone from oxygen updater..
    Does it will have negative effect.. As compared to official update. From phone settings??
    Kevin Thomas Tom likes this.
  15. Abrar@qureshi
    Eclair May 26, 2019
    Touch the 3 dot in top right corner..
    Then in settings select update method..
    And then select oneplus community beta..
    That's it
  16. jigs_0000
    jigs_0000 , May 26, 2019 :
    Is anyone having low call volume issue after the update? I have and it happened suddenly during a call. Till now there are parallel apps malfunctions, rear camera focus, some in between apps lag, and low call volume issues after the app.
  17. rajeevdb
    Froyo May 26, 2019
    rajeevdb , May 26, 2019 :
    Its working
  18. mikica023
    mikica023 , May 26, 2019 :
    Same for me. Mobile network standby bug still persist. CB1, CB2 and 9.0.2. Clean install every time. Deleted cache,data and sistem but the problem Is still present.
    ssaikiran92 likes this.
  19. naveenkushwaha
  20. Pawan or Pritam Jadhav
