791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. ssaikiran92
    Honeycomb May 26, 2019
    ssaikiran92 , May 26, 2019 :
    yes I did the clean install everytime But it's still present. I submitted logs 4 times but no action from OP Dev.
    MarkusRanz likes this.
  2. Athian1991
    Froyo May 26, 2019
    Athian1991 , May 26, 2019 :
    How did you updated bro via normal OTA or oxygen updater?
  3. mikica023
    mikica023 , May 26, 2019 :
    Don't have this problem with 5.0.8 , MNS took 4-5%. But on pie it's 15- 20+ .
  4. Pavan5295
    Donut May 26, 2019
    Pavan5295 , May 26, 2019 :
    hello team, im using 9.0.2 based pie from last Two days...i observed conference call cant be merged and microphone not working if used via bluetooth headphones.please rectify.
    Dwij_Mewada likes this.
  5. Siva_Praneeth_PS
    Froyo May 26, 2019
    Siva_Praneeth_PS , May 26, 2019 :
    Through OTA!!
    After that backup ur data & better to Hard Reset.
    Athian1991 likes this.
  6. Athian1991
    Froyo May 26, 2019
    You are from India right?
  7. Siva_Praneeth_PS
    Froyo May 26, 2019
  8. keets
    Cupcake May 26, 2019
    keets , May 26, 2019 :
    anyone on CB2 recieved the OTA update ??
    I just don't want to update it via oxygen updater !!!
    TheSomeshKumar likes this.
  9. rpavan18
    Donut May 26, 2019
    rpavan18 , May 26, 2019 :
    Does anyone facing notification issue, whenever I replied msg from notification ,that thread still appearing on top with my reply.. it's bit annoying.
    Luechen likes this.
  10. Gautham Kakkente
    Donut May 26, 2019
  11. ShubhamDey
    Eclair May 26, 2019
    ShubhamDey , May 26, 2019 :
    Can anyone confirm their file transfer working properly with a windows pc after the update?
    It was working fine before the update but now it just shows "This folder is empty". I've tried with two different cables.
  12. BlackPanther01
    Gingerbread May 26, 2019
    BlackPanther01 , May 26, 2019 :
    It shows that on my PC too, but there's a trick to it, first click on File Transfer in USB Pref. then click on MIDI and then again click on File Transfer. This should get it working
  13. Dwij_Mewada
    Froyo May 26, 2019
    Dwij_Mewada , May 26, 2019 :
    Yes, I'm also facing same problems
  14. Rahul_2911
  15. ShubhamDey
    Eclair May 26, 2019
    Thanks.
    Also if you change your default USB preferences from developer options, it works just fine. Just tried this process.
  16. iharshjjain
    Ice Cream Sandwich May 26, 2019
    Contin Maurizio_IT likes this.
  17. parharn
    Eclair May 26, 2019
    parharn , May 26, 2019 :
    If updates are always OTA then it is pointless to have a "check for updates" button. It doesn't help in any way. The page check for updates automatically when you open it as well. so I recommend to remove it.
    btw how long should one wait until get the pie update.
    jasprjay likes this.
  18. Rahul_2911
    parharn likes this.
  19. Dwaraka_krishna
    Eclair May 26, 2019
  20. NsrsIndia
    NsrsIndia , May 26, 2019 :
    thanks for detailed info.
    Do you also have battery drain while on stadby due to network. Seems I have this bug. will wait for a week to see exact results.
