791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. G_Ayon_Das_mGEv
    Cupcake May 27, 2019
    G_Ayon_Das_mGEv , May 27, 2019 :
    yes i hve read i have not got ota that why i have asked
  2. Alin Skeptik Tudor
    Gingerbread May 27, 2019
    Alin Skeptik Tudor , May 27, 2019 :
    How do you delete cache on android pie...I can only delete cache from recovery...just asking.
    Other than that...the Pie works great on both my OP3 and OP3T...best update yet. Thank you OnePlus(fan forever)
  3. elanglois
    Lollipop May 27, 2019
    elanglois , May 27, 2019 :
    Apparently, you didn't understand what you read. You might as well ask if anybody in Antarctica got the OTA. Just grab it from one of the download links in the thread. Its safe if you use stock recovery
    sukamaldas likes this.
  4. G_Ayon_Das_mGEv
    thanks 4r the suggestion
  5. enzephalon
    enzephalon , May 27, 2019 :
    Hello
    After upgraded my 3 to Android Pie, USB-tethering is broken / does not work.
    It's very sad!
  6. mohd_areeb
    Honeycomb May 27, 2019
    mohd_areeb , May 27, 2019 :
    High chances to get bricked. Flash Oreo over pie via ADB mode and then reset the device and restart!
  7. atulclassic
    atulclassic , May 27, 2019 :
    go to play store settings..check whether it shows 'Device is certified'.
    if not, then wipe data for Google play services and wipe cache for play store..reboot
    it will show certified after a moment
  8. ShubhamDey
    Eclair May 27, 2019
    ShubhamDey , May 27, 2019 :
    Well I've downloaded 5.0.8 build from the website & flashed it from my stock recovery then format the whole phone. There are no problems & device booted up properly, everything is working fine.
  9. Nishant Ashish
    Froyo May 27, 2019
    Nishant Ashish , May 27, 2019 :
  10. elanglois
    Nonsense! Use a Full ROM update and it completely overwrites what was on the system partition previously. In this case a cache wipe would be good. Worst case is you get a bootloop. Reboot once or twice to see if it fixes itself. If not, wipe data and load the phone as new. Internal storage is fine.
    To brick it, you need to flash firmware for a different model or something. Reload from fastboot. Its nearly impossible to hard brick it, and if you do, there is a Windows recovery tool to reflash the whole system to stock
  11. elanglois
    Do you get an IP? It could be fixable with root
  12. ShinojR
    Froyo May 27, 2019
  13. kattababuji
    Donut May 27, 2019
    kattababuji , May 27, 2019 :
    Fast Battery drainage after Pie based 9.0.2 stable version update. I supposed to charge for twice a day now.
    I used to charge for only once while on stable Oreo build usage.
  14. kattababuji
    Donut May 27, 2019
    Delayed response or No response with Finger print sensor after pie update of 9.0.2 stable version. I supposed to press power button and then finger print sensor is working. I think it is going to sleep mode while screen off.
    G_Shaun_Benny_agrv likes this.
  15. mohd_areeb
    Mind your language, Mr.Old i shared my experience which happened with me in the same case!
  16. elanglois
    Do you know the difference between a brick and a bootloop. If you soft bricked it, then you downloaded the wrong file. Not getting the file for your device will increase the chance of bricking. Downgrading does not.
    And what language are you talking about? I haven't started yet
    Blue-agila, RoverX and elkhan like this.
  17. elanglois
    Its your cache. Let it build. Do we have to explain this EVERY update?
  18. Narender
    Eclair May 27, 2019
  19. PrashantKarma
    Ice Cream Sandwich May 27, 2019
    PrashantKarma , May 27, 2019 :
    if cant wait for ota then update via oxygen updater or scroll up to find a download link and update locally.
  20. enzephalon
    No, I get no IP. And 'root' is not an option, it should run as normal user without modifications.
